Connecting to a seicento 899 s
matthijs_boef
Post by matthijs_boef »
Hi all,
Today I purchase the multiecuscan software because we own 2 fiats. One punto hgt jtd which had an annoying "in need of service" message (I service the car myself) and just successfully reset the interval. The other car (or means of transportation because the word car is a bit to fancy for it) is a seicento 899. Because I would like to check if the temperature sensors make sense I would like to connect my Ecuscan software to it, unsuccessful so far...
I have this setup:
An unbranded I think ELM 327 1.3+ cable (it works with these settings in my punto) and a ODB to 3 wire odb cable.
I hookup all the cables, connect the red wire to the + of the battery, switch on the ignition, try to connect...nothing
Same if I turn on the engine, nothing.
Can someone point me to the right direction?
Thanks!!
Matthijs (Matthew)
Re: Connecting to a seicento 899 s
Hi Mathijs
For your Seicento 899 you need a different interface
namely a KKL interface or the more expensive OBDkey
This ELM interface works only with your Punto
matthijs_boef
Thanks,
Ordered a KKL interface on ebay! I will post success or fail here.
I hope to find watertemp sensor readings and be able to set outputs since the cooling fan does not switch on. I got the car with a leaking head gasket.. nothing bad, just a corroded gasket from a 16 year old seicento.
Matthijs (Matthew)
Post by Waltomatic »
Hello Matthew
Have you checked the fuse and relay?
Walter
