Post by Waltomatic »
Alfaeddy wrote:Hello Walter
Nice to see your link now works :D
but I do not quite understand what you did ???? :?:
Pin 4 and 5 are always connected (mass) [ see the picture: VAG connector only had pin 4 connected ]
Pin 15 is no longer needed since the system is outdated. [ I don't know, only linked these like my ELM ]
the pin 15 is no longer occupied in the vehicles [ I really don't know if the solution was pins 4-5 or 7-15 or both, only that was run after the program found both interfaces ]
But why is your Latency Time have improved ????? [ It was change by himself, after set both interfaces ]
Hello Walter
Then the missing mass was the problem on pin 5 !!
One such error was ever a user ???
I've seen in about 50 KKL interface into but in all pin 4 +5 were associated
Well, was the price for the small cost...
or...
the cost for the small price?
http://www.lightinthebox.com/kkl-vag-co ... rrency=USD
libertyt8
Post by libertyt8 »
Please help me. Which is this board's resistance ?
Version 1.5a usb
Thanks.
Adsız 2.jpg (1.33 MiB) Viewed 8849 times
libertyt8 wrote:Please help me. Which is this board's resistance ?
Version 1.5a usb
Thanks.
Your interface not runs?
dafe
Post by dafe »
Alfaeddy wrote:
dafe wrote:Bad news! I removed the resistor and now the elm doesn't work at all. The led is on but software cannot found it... :( :( :(
Then you have destroyed more than the resistor of CAN bus protocol interferes :? :?
mmhhh i don't think so but it's probably. However RIP
Hello libertyt8
As Walter already asked?
What does not work?
Which vehicle you would like to read?
What control?
A more detailed description can help us very much to help you.
Remove the white plug housing to please the 8pin bar
and do another picture of it
libertyt8
Post by libertyt8 »
1. I can't see datas which in this photo
2.I can't see like these options " Bady, Service, Other"
hello libertyt8
Which vehicle?
And as already written, remove the white plastic base on the 8pin bar and take a picture of it
libertyt8
Post by libertyt8 »
My car's 2005 Marea Liberty 1.6 16 valve
Solder how it turns out
