Where is the "Proxi Aligment procedure" ??
Hello Yani and all other
I was called a friend today.
He was in his Alfa 147 another radio, login Bus System in CAN.
It does not work because it has the function "Proxi Aligment procedure" not found.
I checked and this function in the body computer is no longer available ???
Also in Alfa 159, Alfa GT, etc. Mito is the adjustment function "Proxi Aligment procedure" no longer exists.
If the function was removed from the program?
Or has something changed in the process?
Another friend would like to also install the original radio in his Lancia Ypsilon, but login is not working.
It lacks the Proxi Alignment
Thanks for your answers
Eddy
Re: Where is the "Proxi Aligment procedure" ??
Can you post screenshots of this?
We have not removed the PROXI procedure. It could be some kind of bug.
However, I just opened Multiecuscan 2.1 and checked the body section of 147,159,GT,Mito and some other cars and the "CAN Setup / PROXI Alignment" is there.
Hello Yani
I just realized that I was wrong probably :)
Was probably a little late last night :oops:
I did not notice that the proxy settings have been well re-sorted.
and the general approach now has a blue background and is also at the beginning.
The individual strands are highlighted in red.
Is this correct?
I've probably seen wrong :oops:
Alfa 147.jpg (117.41 KiB) Viewed 5045 times
Yes, that's correct!
We changed this probably a year ago. The configurable options are in red and the PROXI procedure is in blue on top.
