ELM 327 bluetooth won't connect
CreativeSound
Post by CreativeSound »
Hi all, I have an ELM327 bluetooth and I can't connect to the car. How can I check if the problem is the interface or pc settings? I connect bluetooth and serial port service with COM port 13, when i click on test in Multiecuscan (DEMO) settings it says the interface is compatible with CAN protocols. The problem is when I click on "Connect" it don't start any connection!
Re: ELM 327 bluetooth won't connect
Which vehicle would you like to read?
Otherwise, I suspect that your error is described here.
viewtopic.php?f=5&t=1493
CreativeSound
I'm trying on a Stilo 120HP EDC16c39
Then it is not specified by me problem with the bridge resistor
Because your control is not read via CAN bus.
Which driver do you have installed?
Have you asked the Latency Time in 1?
Just try a different COM port set.
It can probably be only setting error
CreativeSound
I install bluetooth drivers only. There's someone for ELM327 too?
Install this driver and test again
Gruß Eddy
CreativeSound
Excuse me but with bluetooth ELM327 I have COM port only in device manager on windows so were I install drivers? I erase bluesoleil and paired with windows bluetooth application and now I have timeout message when try to connect. Seller says that without license the interface can't work well but I seems strange because unavailable modules are highlighted in red.
Bluesolei is only necessary for the Bluetooth connection.
To operate the interface, the driver will I need you
have called in a link.
The other settings should be checked and adjusted.
You red controls are only of limited use, but a connection should also be possible with the free version.
Otherwise appears you that you need the registration for this controller.
