Steering wheel and automatic trans AR159 1,9JTDm
cendler
Post by cendler »
To activate the buttons on the steering wheel for the automatic transmission + and - how to do it?
Everything is connected and does not work well, what else must be done?
cendler
Re: Steering wheel and automatic trans AR159 1,9JTDm
Post by cendler »
no one knows
It is very easy.
Go to "CAN setup/ Proxy procedure" > then to "F7 Settings" > then to "Steering wheel buttons" > then select "F10 Execute > then select "Enable" > then "OK" > Then do the "PROXY procedure".
That is all!
I do not have time to put photos of all detail procedure...
cendler
Post by cendler »
alfa156sarajevo wrote:It is very easy.
That is all!
I of course tried, but it did not work. There is a choice of this, I tried to type B, 8 buttons; type C; type D / 159; type F; type E, 10 keys, of course, I gave each of the proximal delimitation and it does not work and what to do.
cendler
Post by cendler »
sorry english
If you done Proxy procedure after the selecting the type then it should work.
I tried it once on Stilo and did worked! I did nor tried on Alfa 159. Did not had the chance...
Procedure is obviously the same just in case with 159 does not work.
Or it is a bug in MES or 159 are made a little bit complicated.
I know that with man had problems installing cruise control on 159 mjet.
At the end he reprogrammed with additional programmer the body electronic and cruise control did worked. :roll:
cendler
Post by cendler »
Proxy alignment every time and I did not really
The "Steering wheel buttons" function in PROXI settings is for the Radio/Blue&Me controls on the steering wheel.
It does not control the gearbox paddles on steering wheel.
Yani you are right.
I did not understand the question very well.
I understand that he changed steering wheel from normal one with the other one with buttons...
cendler
Post by cendler »
hmm, but it still does not solve my problem
