dxvanzin
Post by dxvanzin »
alfa dealer can't do anything forse this kind of modifications....
Can the Alfa dealer does not it?
or
makes the Examiner dealer this does not?
dxvanzin
Post by dxvanzin »
hi
both examiner and wiitech plus are no able to align proxy on car that were accessorized wit new devices aftermarket.
idan182
Post by idan182 »
I have a 2001 Punto (MK2 - SX)
I got my ELM327 cable from this ebay link:
http://www.ebay.com/itm/400465763167?ss ... 1497.l2648
It's a chinese one.
I'm using the free version of Multiecuscan, I can connect to the Engine ECU but not the Delphi Steering Wheel.
I only want the diagnose the steering wheel.
Do I need to fix my ELM cable like in the pictures? or the Steering Wheel section should work without any changes?
This is how my PCB look like:
This interface we had already several times here
Remove the red marked Resistor and you would have to also be able to read your steering control.
149z39j markiert.jpg (100.93 KiB) Viewed 8864 times
idan182
Post by idan182 »
Thanks Eddy! will try that.
idan182 wrote:Thanks Eddy! will try that.
Please :D
And report here if it works now.
mushis
Post by mushis »
Hello i've just registered at this forum because im interested into buying a cheap chinese ELM 327 interface (bluetooth prefered) for my Lancia delta iii (2009).
I've read several pages, and all i see is ppl asking for help, some solutions given... how about recommending some proven-to-work ELM327 interfaces? or simple-to-work ones? i've been browsing on ebay and have found these
http://www.ebay.co.uk/itm/Super-Mini-ELM327-1-5-Bluetooth-OBD2-OBDII-Car-Diagnostic-Interface-Scanner-Tool-/181165811348?pt=UK_Diagnostic_Tools_Equipment&hash=item2a2e52e694
http://www.ebay.com/itm/ELM327-V1-5-Bluetooth-OBD2-OBDII-Auto-Car-Diagnostic-Interface-Scanner-Tool-/171283548607?hash=item27e14b89bf&item=171283548607&vxp=mtr
but after finding this forum i got scared :) can you guys recommend? and maybe put on the 1st page, with link and description of working interfaces?
Thanks!
edit: i've found this recommended by eddy some pages back. but it's twice the price! ;( http://www.ebay.de/itm/151018227295?_tr ... EBIDX%3AIT
edit2: sorry, im so newbie that i don't know: do i need to buy adapters to work with the elm327 interface? adapters like this http://www.gendan.co.uk/product_FESCBL.html (link grabbed from AlfaOBD page)
In the two ELM 327 interface must still open and a resistor be removed.
In the ELM 327 from my link, you can use the interface without modification. So directly.
This seller has changed its interface according to my information.
Decide what you want.
To on your Lancia Delta read everything you need for ABS and steering still the green adapter
http://www.ebay.de/itm/151016679362?_tr ... EBIDX%3AIT
If you have a ELM order at Diadig, send the seller with a greeting from me (Eddy). :D
mushis
Post by mushis »
you can count on that :)
Thank you.
