multiecuscan 1.5
roby68
multiecuscan 1.5
Post by roby68 »
Good evening,i have a problem with multiecuscan free,don't connection with fiat qubo natural power with elm 327 v1.5.I set the port and the test port is ok,but impossible connection.Please help me.Many thanks.
Re: multiecuscan 1.5
Hello Roby68
First you need the registered version of Multiecuscan with the free version you can not get much :-)
Only to "CAN info" you can make with the free version full connection
If this does not work:
Your problem is known and has often been described here
Multiecuscan can read your interface with no CAN bus protocol
In the interface a bridge resistance is present when the Multiecuscan read disturb
Here you will find a lot to
viewtopic.php?f=5&t=1493
roby68
Post by roby68 »
Thank you Eddy,but the my interface is 1.5 and does not have the resistance that you see in the picture.I have connected this interface with scan master and connected with engine ecu is ok, it's very strange this problem.why the connection with scan master with engine ecu is ok and with multiecuscan not?Many thanks.
Hello Roby68
This comes in this particular case often that the interface with other programs work, but not with Multiecuscan :-(
If you see this resistor (not resistance) have checked!
You probably have a problem with the drivers or settings.
roby68
Post by roby68 »
I Alfaeddy,with mutiecuscan i can connection with fiat panda 1.2 year 2005 but not qubo,panda and qubo use both for connection can line? if so, why the panda is connected and qubo not.Many thanks.
Well then it should be clear so that your interface has this resistor problem
Look in the link above mentioned and to remove the resistor
roby68
Post by roby68 »
Good evening every body,this is my elm 327 1.5, where is the resistance to be removed?Many thancks.
2013-06-21 18.51.55.jpg (791.16 KiB) Viewed 6443 times
Hello Roby68
Your interface has no CAN bus disturbing resistor
Thus the CAN signal Multiecuscan should have no problems.
Check the settings again and the driver
roby68
Post by roby68 »
Hello Eddy,i setting the port of interface,the velocity,is every ok.I send you the result.
Nuovo documento di testo.txt
(826 Bytes) Downloaded 421 times
roby68
Post by roby68 »
Hello Eddy,in this moment i connected to qubo with alfaobd free and the connection is perfect with engine ecu, abs, airbag.At this point the problem is the multiecuscan and not the elm.what do you think.thancks.
