Hi Lolo85v
I cant see the numbers from the Chip
where ist the Chip MCP2551 ???
Please make a image without flash
Have an Makro Modus in your Kamera ??
Hi Lolo85v
I see you have an Alfa 159
Can so you have a connection to the engine control unit
That must always work on Alfa 159
Otherwise, your error is a setting error!!
lolo85v
Post by lolo85v »
Hi Lolo85v
Answer me look at my question!
Can you make a connection to the ECU?
And the board has no problem with the CAN bus
It should work without problems
lolo85v
Post by lolo85v »
Not of connection has the ecu
Then I have to say it again again again
It's not the Problem with the ELM interface!!!
check
- driver
- settings
- COM port
lolo85v
Post by lolo85v »
Hem I have to try several computer experimental plusieur I have this message has the connection ecu on the other hand I arrive has to connect me has bodysuit
I really have no luck(chance)
http://i69.servimg.com/u/f69/13/77/86/13/sans_t12.jpg
lolo85v
Post by lolo85v »
With that her(it) you to confirm me that he(it) is functional?
http://www.ebay.fr/itm/CAN-327-Interfac ... 3373ff4313
Hi Lolo
Yes it works Guaranteed
If software, drivers, and settings are correct
Send the dealer a greeting from me (EDDY)
But your OBD interface should also work
lolo85v
Post by lolo85v »
Here is it is to command(order) on the other hand for my elm they it connects everything has modulates them except driving thus can being one resistances is missing?
