Hi Lolo85v
I cant see the numbers from the Chip
where ist the Chip MCP2551 ???
Please make a image without flash
Have an Makro Modus in your Kamera ??
Hi Lolo85v
I see you have an Alfa 159
Can so you have a connection to the engine control unit
That must always work on Alfa 159
Otherwise, your error is a setting error!!
Here were better one photo the friend the flea(chip) mcp2551i
http://i69.servimg.com/u/f69/13/77/86/13/20130416.jpg
http://i69.servimg.com/u/f69/13/77/86/13/20130417.jpg
Hi Lolo85v
Answer me look at my question!
Can you make a connection to the ECU?
And the board has no problem with the CAN bus
It should work without problems
Not of connection has the ecu
Then I have to say it again again again
It's not the Problem with the ELM interface!!!
check
- driver
- settings
- COM port
check
- driver
- settings
- COM port
Hem I have to try several computer experimental plusieur I have this message has the connection ecu on the other hand I arrive has to connect me has bodysuit
I really have no luck(chance)
http://i69.servimg.com/u/f69/13/77/86/13/sans_t12.jpg
With that her(it) you to confirm me that he(it) is functional?
http://www.ebay.fr/itm/CAN-327-Interfac ... 3373ff4313
Hi Lolo
Yes it works Guaranteed
If software, drivers, and settings are correct
Send the dealer a greeting from me (EDDY)
But your OBD interface should also work
Here is it is to command(order) on the other hand for my elm they it connects everything has modulates them except driving thus can being one resistances is missing?
