I was trying to see if the turbo still works correctly on my 156 2.4 jtd 136hp, so when i tried to make a log with: rpm, desired boost and actual boost pressure i saw that the desired boost is 0 regardless of the rpm .If i understand correctly desired boost pressure should be the boost requested by ecu if so why i'm not seeing the real value?
I use elm 327 1.4 ,multiecuscan 1.3 .No errors on the engine.
Any help will be appreciated.
alfa 156 2.4 jtd desired boost pressure 0
Re: alfa 156 2.4 jtd desired boost pressure 0
Your car does not use electronic boost control. It is controlled mechanically... so there is no need for "desired boost".
