Hello Elio65
Unfortunately, the images often of poor quality, you unfortunately also :-)
Your photo flash makes everything very dazzle
But when I look at the board, I can see I should have found the resistor.
And I marked the red
Should remove this resistor and also work with your ELM Multiecuscan
20130219_161056 markiert.jpg (102.74 KiB) Viewed 6838 times
ELIO65
Post by ELIO65 »
Sorry Eddy,
My outside interface is as follows:
While inside is as follows:
Thanks for the help!
Hello Elio65
Sorry but the second images are even worse than the first!
55 kb per image are far too few
And this photo flash without
jerrywang
Post by jerrywang »
it is my car OBD interface,i removed the 120ohm resistor,also i add the 560PF capcitor and 100ohm resistor on pin 6 and pin 14.but till now i can't connect to anything,Engine,ABS,Body and so on.....
would you pls tell me how can i do for it?
Thanks a lot :|
Giuseppe
Post by Giuseppe »
I bought un'elm327, and when I go to read, with Fiat ECU scan, the data of ABS and airbags, I find the error that can not be read on the K-line to pins 5 and 7 ....... it seems to me;
how can I change it, I'll post pictures:
Hi Giuseppe
Which car / model / year you want to read?
And why here all have such bad pictures representing
can not see anything? :-)
The images must have a higher resolution of at least 800 kb <
In these pictures, I can not see anything
Giuseppe
Post by Giuseppe »
FIAT, Alfa, Lancia Group,
Fiat Stilo, and Fiat Croma
Giuseppe
Post by Giuseppe »
OK, I try to do the best photos.
Fiat Stilo 2005 years 1,9 MJT 120CV
Fiat Croma 2008 years 1,9 MJT 140CV
Hi Jerrywang
Your pictures are too big and have nothing to do with your interface!
Why did you set here?
800 x 600 pixels is sufficient
It is clearly not an interface :-)
Which car / model / year you want to read??
If you still have soldered a capacitor (560 pF) and a resistor (100 ohms) to pin 6 + 14?
This is completely unnecessary, remove it again
Hello Giuseppe
Please this time slowly
This ELM interface you can convert without something
on Fiat Stilo read the ECU / ABS / Steering
For the air bag you need a KKL interface
For the Fiat Croma
So you can read without a rebuild your ECU / ABS / xenon
Only for the airbag / Body Comp etc. you may need to change something on the interface.
If you get no connection to the ECU you have the settings / Com port set incorrectly
First check the time settings
