Hello Farris
Strange?
I can see nothing that you could do wrong!!
And since the other function controls all
I suspect an error in the data transfer
Your interface does not make mistakes, otherwise the other controls have not read it.
I can only give you the tip to change the data rate (115000 now right?)
'll try another
Maybe something changes, just an attempt
Or even another interface! just a try
Otherwise, I suspect a fault in the ABS
farris
Post by farris »
Alfaeddy wrote:Hello Farris
Strange?
'll try another
Yes it is very strange... I can try a lower speed, but I don't think that is gonna help. But it's worth a shot.
Do you have any idea why I can't do a forced regeneration of the DPF? I always get an Unknown Error... also, the parameter 'Forced Regeneration Status' gives 'Error'
Strange stuff with this car.. hehe
Hello Farris
Unfortunately, I do not tip for DPF
Only I read that works if not the manual regeneration
should be 50 - go 60 km on the highway
And the differential pressure (charge state) before and after test
Vasil82
Post by Vasil82 »
Hello,sorry my englisch is not so good.
I have a problem connecting to Alfa Romeo 156 1.9 JTD 1998 year
When i test port in multiecuscan i get all ok. But when i try to connect i get connection timed out or nonexistent port
Tell me what to do or to remove
Thanks in advance
This is my ELM327
Hello Vasil82
You can use your ELM interface Reassemble :D
The connection to the Alfa 156 has nothing to do with the errors described in this thread.
Your connection error has something to do with the settings.
Valid
- Beta drivers installed
- Latency Time set to 1? (Instead of 16)
- Correct interface set?
- Com port checked?
Vasil82
Post by Vasil82 »
Hello Eddy
Latency is 1
I think that interface is correct ELM 327 1.3+
Here are a few photos and tell me where they be wrong
Hello Vasil82
If you are the different interface all on the same com port (com3) may have problems logging in
Remove times the other interface or the com port for that and try again
ELIO65
Post by ELIO65 »
Hello, I' m Italian, sorry for my English.
I bought a bluetooth ELM327 with Torque works perfectly, while multiecuscam I can not connect.
Fiat 500 1.2
Windows 7
Multiecuscam 1.3 free
The test interface to this result:
RESPONSE: ATZ
ELM327 v1.5
ELM327 v1.5
RESPONSE: OK>
RESPONSE: OK>
RESPONSE: OK>
RESPONSE: OK>
RESPONSE: OK>
RESPONSE: OK>
RESPONSE: OK>
RESPONSE: OK>
RESPONSE: OK>
RESPONSE: OK>
Everything seems ok, but when I try to connect I get this:Image
This is the type of error that was described in this Multiecuscan thread again.
Open your interface and look for the question and remove the resistor then the interface is also Multiecuscan and Torque
ELIO65
Post by ELIO65 »
Thank you Eddy, you're very kind.
My interface is like this outside, but the PCB is different.
I can just do some pictures.
I hope you'll help me again.
Ciao
bluetooth wrote:I have ELM327 with MultiECUScan Software and 2004 Fiat Stilo 1.6.
I can not connect to Body Computer or Proxy module.
I can connect to only engine module.
How is repair this ELM327 ?
Please check it pictures.
Thanks a lot.
