oz42
Posts: 12 Joined: 29 Dec 2012, 08:07
Post
by oz42 » 17 Feb 2013, 11:29
Tried FES 1.3 today, still no luck. F11 searches for a while and finds nothing.
On the ECU I read the label ME73 M003 - I think. Old eyes, dm light and tiny characters on the label.
Which of both available ECUs should I select then?
Olaf
Posts: 1350 Joined: 19 Feb 2011, 17:43
Post
by Alfaeddy » 17 Feb 2013, 15:45
Hello Olaf
For ME7.3 you need the registered version
I am surprised that the old FES Verison 1.3, this control has ME7.3 in the program?
Can you make a connection (adapter A2) to the airbag?
As already wrote alfa156sarajevo
This should go well with the unregistered version of FES.
oz42
Post
by oz42 » 17 Feb 2013, 17:37
Sorry for the confusion, I meant: I tried M ES 1.3 today, not FES. About airbag: I will have to modify the KKL interface before which I won't do today.
Thank you for helping!
oz42
Post
by oz42 » 03 Mar 2013, 12:59
I disconnected pin 7 and connected the board to pin3. Result: the interface is not detected anymore.
Post
by Alfaeddy » 03 Mar 2013, 13:44
Strange?
After this assignment, you should only be able to read on your airbag.
It may be broke in changing?
some do a test
Multiecuscan / Settings / Interface / K-Line VAG (test)
oz42
Post
by oz42 » 03 Mar 2013, 14:20
I just changed the lower lambda probe and tried to clear the MIL with my generic scanner.
It did not find the ECU...
I disconnected the battery and checked all three ECU fuses, they are okay.
After reconnecting the battery, my generic scanner found my ECU again.
About MES: Multiecuscan / Settings / Interface displayed no interfaces.
Post
by Alfaeddy » 03 Mar 2013, 15:35
If you changed the connection from pin 7 to pin 3, you can´t make a connection to your ECU!!
But only to the airbag!
your message
IT must of course the correct com port and interface have been set!
Otherwise Multecuscan not work with the interface
