Not connecting to dashborad node
Beaniesbcfc
Post by Beaniesbcfc »
HI can someone help me out hear please.
I am trying to connect to my Dashboard node and service but it keeps saying check your cable/serial port setting but all of the over stuff is working fine so i know its not the cable or setting and i have the payed version of the software. :?
Re: Not connecting to dashborad node
Which interface do you use?
Which vehicle do you want to read?
Beaniesbcfc
It is a alfa 147 1.6 ts lusso and the interface is ELM 327 1.3+
The ELM v1.3 is already older?
What connections can be done??
ECU Can setup; Can info; service?
The following ELM Interface v1.4 - v1.5 have the CAN Bus Protocol
Multiecuscan with a connection problem
read here
viewtopic.php?f=5&t=1493
If you can establish no connection you should check the settings
Beaniesbcfc
It works fine with all of the over ones just not Dashboard node and service and i used it around 2 weeks ago and it was fine then. This has just started to happen after i put a new head unit in.
Beaniesbcfc
sorry it's v1.4
With the CAN setup you can make a connection?
Even with the Delphi Climat Control the connection works?
If a boot and Driver Door TRW TRW it works?
For the ELM v1.4 can not do this without the file is modified
Beaniesbcfc
Yes the connection works on the Delphi Climat Control /boot and Driver Door TRW and the body just not the dashboard.
Hmmmmm???
Strange thing trying some different speeds
instead of 38400
Or other ELM Interface
Otherwise, I do not continue, sorry
ELM Test.jpg (35.42 KiB) Viewed 5956 times
Beaniesbcfc
Ok i will and thanks for your help Eddy
