It was sold as ELM 327 1.4 'with a genuine ELM chip'.
Best regards
Sébastien
hello, i recently bought an elm 327 interface, and now saw that the interior is equal to what is said above, I have to make any changes to operate at 100%? if so which?
already now what program I can use and where to get complete, or cheaper if possible for free ..
after scrolling through the previous 47 pages I did not find any user having exactly the same layout as I have bought now. It is similar to the one posted by "Franky" on page 27 (viewtopic.php?f=5&t=1493&start=260#p10022). My ELM is labelled "Autodia E327".
Can one of the pros check the layout and state if a resistor has to be removed at all?
If yes, would that be the "r04" like shown in the following posting? viewtopic.php?f=5&t=1493&start=280#p10449
I do not understand what you want?
- Which vehicle you want to read?
- This vehicle is to be read with the ELM?
- With the free version you can work from Multiecuscan
- Multiecuscan is not expensive
I can not translate your post, but as I understand you have a ELM 327 and can not connect? right!
Absolutely no connection or only partially?
For the service and a few other controls you need an adapter!
In your ELM 327 the resistor is often described herein has been removed. ?
Have you registered the formatted version of Multiecuscan?
Did you install the correct driver? not supplied from the CD
Today i could connect to my grande punto, i have the multiecuscan registered, where can i buy the adapter to conect to service?
i only can see the errors from the motor
