henrikl88
Post by henrikl88 »
sprint750 wrote:Hello,
It was sold as ELM 327 1.4 'with a genuine ELM chip'. :?
Best regards
Sébastien
hello, i recently bought an elm 327 interface, and now saw that the interior is equal to what is said above, I have to make any changes to operate at 100%? if so which?
already now what program I can use and where to get complete, or cheaper if possible for free ..
thank you
markw
Post by markw »
after scrolling through the previous 47 pages I did not find any user having exactly the same layout as I have bought now. It is similar to the one posted by "Franky" on page 27 (viewtopic.php?f=5&t=1493&start=260#p10022). My ELM is labelled "Autodia E327".
Can one of the pros check the layout and state if a resistor has to be removed at all?
If yes, would that be the "r04" like shown in the following posting?
viewtopic.php?f=5&t=1493&start=280#p10449
Thank you for your help!
Mark
Hello Mark
Yes, this is the relevant resistor (R04)
remove this resistance and your ELM CAN bus capable
I have to once again marked in red
IMAG0191 markiert.jpg (432.82 KiB) Viewed 10332 times
Hello hendrikl88
I do not understand what you want?
- Which vehicle you want to read?
- This vehicle is to be read with the ELM?
- With the free version you can work from Multiecuscan
- Multiecuscan is not expensive ;)
markw
Post by markw »
Thanks Alfaeddy!
After un-soldering the marked resistor my ELM works perfectly :D
gladly markw :D
henrikl88
Post by henrikl88 »
i want to read a fiat grande punto 1.3mjt but i can t
i have the elm327 cable
i can do a reset os fervice neither read the erros
Hello Henrikl88
I can not translate your post, but as I understand you have a ELM 327 and can not connect? right!
Absolutely no connection or only partially?
For the service and a few other controls you need an adapter!
In your ELM 327 the resistor is often described herein has been removed. ?
Have you registered the formatted version of Multiecuscan?
Did you install the correct driver? not supplied from the CD
henrikl88
Post by henrikl88 »
Hello, thanks for the help
Today i could connect to my grande punto, i have the multiecuscan registered, where can i buy the adapter to conect to service?
i only can see the errors from the motor
I figured that your problem is a lack of adapters
You need the yellow adapter (A3)
Question time with this dealer about whether even the yellow adapter (A3)
individually has on offer.
With a nice greeting from me (Eddy)
http://www.ebay.de/itm/Adapter-A1-A2-A3 ... 2578c4a7bc
