Which vehicle do you want to connect and Bj?
It depends on whether only CAN bus or KWP2000
Without more detailed information you can help no one here
And your pictures are very difficult to recognize
Connection problems with ELM327
Re: Connection problems with ELM327
car is punto '99 1.2 8v and i vant to connect with abs and body
To come to your ABS you have the wrong interface
For this purpose you need a KKL interface and an adapter cable
or a modified KKL Interface
With your ELM you should test also get the body, please make a better picture. To see if your ELM also has this annoying resistor
This resistor only applies to the CAN protocol
this is my elm only without bluetooth what can i do? thanks
- P1050833_k.jpg (165.08 KiB) Viewed 3934 times
- P1050834_k.jpg (118.03 KiB) Viewed 3934 times
Remove the red marked resistor R04
It should also make the body tie no more problems
- P1050833_k markiert.jpg (79.73 KiB) Viewed 3932 times
