Problem with reading ABS and Airbag
p029351
Post by p029351 »
Have a registered version of Fiat Multiscan windows vista Elm Bluetooth adjusted resistor delete.
But can not connect to the ABS and Airbag although I the red / green / yellow cable connector use no result.
The motor can I read out.
I also have a USB cable also Elm with modification (removes resistor) but unfortunately not with the ABS and Airbags.
Sorry for the bad english.
The car is a Alfa Romeo 156 JTD 1.9 year 2004
Doc1alfa2.docx
(128.62 KiB) Downloaded 606 times
Doc2alfa.docx
(120.9 KiB) Downloaded 532 times
Bleuthoot USB.docx
(64.68 KiB) Downloaded 516 times
Re: Problem with reading ABS and Airbag
With the ELM interface you can only connect to the ECU of your Alfa 156 produced.
For the ABS and airbag you need a KKL interface. (modified or with adapter)
This you can see in the list of Supported Vehicls.
To remove the resistor for the CAN bus is important to read.
But the 156 does not have any CAN bus
p029351
Post by p029351 »
I used VAG COM for my VW with a homemade interface that worked perfectly.
If I would use this interface with the adapter cable (red / green / yellow) then it should work?
Yes I do think it works.
Only I do not know your Homemade interface.
But why it should not work
p029351
Post by p029351 »
With VAGCOM self-built interface. I could read everything and adjust.
I will try it and if it works I will let you know.
For now thanks
p029351
Post by p029351 »
Hi Eddy,
Unfortunately, my homemade interface adapter with the red, green, yellow adapter does not work.
So I need to find a KKL interface.
Thank you for the advice.
meduza-perduza
Post by meduza-perduza »
Having read this thread I bought myself a K409 interface from here http://autodia.de/produkte/autodia-k409 ... sche-daten which I suppose to be KKL. However I still can't connect to Airbag and getting something like "Can't connect to ECU. Please check cable and port settings". Connecting to Engine runs fine.
Please advise.
Regards,
Tim.
By KKL but you should come to your motor controller!
Have you installed the FTDI driver for the KKL?
And the settings in the Control Panel and Multiecuscan
changed?
For ABS and airbags you need either a modified KKL
or
The two adapter cables.
Which vehicle do you want to read?
meduza-perduza
Thank you for your reply.
It is Alfa Romeo 147 2.0 TS
I have not installed any additional drivers and have not changed any settings. Please let me know what shall I do.
Thank you in advance,
Tim.
Hello Tim
Install this FTDI driver for your interface and Windows
And then make your settings are marked as in the pictures.
Einstellungen Systemsteuerung.jpg (173.8 KiB) Viewed 9003 times
