I have a Multipla 100, 1.6 16v 1999. Its a nice practical car and looks great
I bought a scanner U480, but it says linking error. Then I bought a Kiwi Wifi interface and REV2 app for my iphone, but it connects only for 1-2 secs only to disconnet again. Now im thinking about using multiecuscan, but apparently there are 3 different adaptercables to choose from.. Witch one should I choose? Right now I think its K1, but not sure..
If I get the right cable, can I the use my scanner U480 or my Kiwi Wifi Interface?
Daniel
Help - Multipla cable adapter for multiecuscan
Re: Help - Multipla cable adapter for multiecuscan
My personal recommendation for you is to buy a VAG COM KLL 409.1 cable which will work for your Fiat Multipla 100, 1.6 16v 1999.
Option 1: Buy already modified KKL cable
Option 2: Buy normal (unmodified) KKL cable + you need to buy adaptors (A1 and A2).
Just go to ebay.co.uk or ebay.de or ebay.com and there you can find both normal and modified cabels (interfaces)!
Ok?
That I will look in to..
But why do I need to have 2 adaptercables? (A1 + A2)
I thought it would be enough with just one
Is this the cable? I dont know if it is modified or not..just says that it works on vw, seat, audi etc..
If its tthe wrong one can you then post a link to the right one?
Well the A1 cable made for connection for ABS, engine, xenon lights, steering...danielsigsgaard wrote:Ok?
And the A1 cable made for connection for airbag system.
The airbag system is very sensitive and that is why is necessary to have separate adaptor.
Just visit: http://www.multiecuscan.net/SupportedVehiclesList.aspx
and maybe you will have a little bit clearer image about adaptors
Maybe this topic can help you: viewtopic.php?f=5&t=2736danielsigsgaard wrote:Is this the cable? I dont know if it is modified or not..just says that it works on vw, seat, audi etc..
