Hoping someone can help.
Unable to do proxy alignment after abs module change. I'm using multiscan and elm327 and required adapters.
I can only access engine, transmission, and now Abs , still uable to access bcm.
Keeps coming up with check adaptors and vehicle information.
Ive been trying to fix a problem with comfortmatic gearbox with only 1st and reverse gear. Has any body had this same issue?
