Hi Yani.
When I connect my Fiat Panda 1.2 Natural Power to Multiecuscan 2.1.1 I get the message “Invalid ISO code, press Y to Continue or Press N to Abort”. Pressing Y the program seems to work.
My question is: service reset is still possible on my car, or this error message means this function will be not available?
These are the parameters shown by Multiecuscan when I connect to "Fiat - Panda '03 1.2 8V - engine":
- ECU ISO code: 0D 07 40 83 2C
- FIAT drawing number: 51798646
- Hardware number: IAW5AFHW603
- Hardware version: 00
- Software number: 21BAWG3
- Software version: 0000
- Homologation number: 5AFSK
- ECU programming date: 02/25/2008
These are the parameters shown by Multiecuscan when I connect to "Fiat - Panda '07 bipower - service":
- ECU ISO code: 32 83 A8 85 37
- ECU programming date: 03/12/2008
Thanks for your support.
service reset possible on a Panda if I get invalid iso code?
Re: service reset possible on a Panda if I get invalid iso code?
Yes, you can reset the service interval.
You have to select "Service Interval Reset (Comfort)", and it will not give you "Invalid ISO Code". This is the correct option for your car.
