DRL recode to suit LED bulb upgrade?
richy-m-g
Post by richy-m-g »
Dear all,
I have a 2016 Fiat Doblo. I recently changed the T20 DRL bulbs from incandescents to LED's.
Unfortunately they trigger a Check DRL lights message on the dash when in use.
This message goes off however when dipped beam is on and the DRL's run on reduced power.
Is it possible to use the software to get the ECU / BCM to accept the LED bulbs and not trigger an error message?
I have a registered copy of Multiecuscan v4.9 from Gendan.
Thank you.
