hi, I would like to activate the tsr, traffic sign reconition, there is no option directly on MES, I wanted to know if anyone has a list of bytes to configure, I think the 500x is also fine which is very similar to the jeep.
this option is by default in models after 2019, mine is from 2018 but in many forum say it is also present on previous models.
can someone help me ? Thank you (GRAZIE !! )
jeep renegade byte config for enable TSR
Re: jeep renegade byte config for enable TSR
you can try with another configuration software.. MES doesn't have the possibility to do this, other than manually changing the proxy bits, but I don't know what they are..
ciao
ciao
