Hi @Yani
If I am right so on the Byte 31 value 02 is Dosing Control Unit (DCU) not RRCM Rear Right Climate Control Node as is now in CAN list...
Please correct it.
Thx
Michal
BUG - Wrong DCU // RRCM node position
Re: BUG - Wrong DCU // RRCM node position
Today I did proxi configuration o Ducato MCA 2023 and proxi alignment procedure has fail.
It reports Dosing Control Unit (DCU) as Security Gateway Module (SGW) - byte 31
But SGW module is on the byte 40 and it is always hidden (menu of enablimg SGW works well)
Hi chrener
I'm not sure how often Yani checks in here as he is always very busy. Suggest you send MES Support a bug report Email.
Question for you.
You say the SGW enabling menu works well. What do you mean?
I assuming that being a later Ducato the SGW is in the body computer?
I've also looked on MES ath the Ducato 290 MCA and can not see any mention of the SGW / SGW menu.
Please explain.
Question for you.
Please explain.
Hi S130,
I mean that you still have to enable SGW module before runing proxialignment procedure, because it is deleted from proxi - I dont know why.
But SGW and other units (esp. hybrid control proccessor etc.) are showed as released, but they are always working.
So without addidg it manually into proxi code you release them from proxi and I dont know what will it cause.
You can compare the table of proxi in MES program with proxi saved in log file and they are different...
Here is picture with SGW enabling in Ducato X290 MCA list
- X290MCASGW.png (65.89 KiB) Viewed 47061 times
