Hi Yani,
I have an ELM327 clone.
My problem, that I can connect with this ELM only to the ECU of engine. The other connections (service reset, etc.) aren't estabilished.
Help Me, please!
Joseph
Here are the multiecuscan's test results:
RESPONSE: ELM327 v1.5a>
RESPONSE: ATE0OK>
RESPONSE: OK>
RESPONSE: OK>
RESPONSE: OK>
RESPONSE: ?>
RESPONSE: OK>
RESPONSE: OK>
RESPONSE: ?>
RESPONSE: OK>
RESPONSE: OK>
RESPONSE: OK>
ELM327 problem
Re: ELM327 problem
Your ELM interface does not support v1.3 commands. It will not work.
Re: ELM327 problem
Thanks!
It is nice.
I read on this site, that "You need to have a k-line (VagCom) or ELM 327 v1.3 (or later) interface cable in order to use this program."
What is the reason? Because it is a clone, or I have wrong version? The v1.5a is not a later version of v1.3?
It is nice.
Re: ELM327 problem
Well, in this case, it is not.joseph67 wrote:The v1.5a is not a later version of v1.3?
Your interface actually seems to be v1.2.
Re: ELM327 problem
The 1.5a interface is a fake...
Lastest is 1.4 but is very difficult to find. (because 1.4 specification has been released just a couple of months ago.)
So, lastest that you can buy is 1.3
