Unable to see airbag errors
Danxq
Post by Danxq »
Hello, I am using mes 4.8 with Elm 327 with or without red adapter I am stuck when clicking on Airbag error review with message Reading Error Code. Light came on when battery was changed, the module is listed, all airbags are seen.
Fiat Freemont 2012 2.0mjtd2 6at
Any ideea what to do?
Re: Unable to see airbag errors
I'm not sure what you are asking?
MES has connected to the Airbag ECU and is showing a Error Code?
What is the Error Code and what decription does MES give for the error?
Have you tried to CLEAR the error?
Also have you checked the Parameters looking for wrong / different values?
try doing Scan DTC
