NEW 2023 Ducato no adjustment of Tire pressure?
malibu
Post by malibu »
Hi everyone,
is it correct, that there is no way of adjusting the Tire pressure anymore?
Has no separate listing point in the Vehicles list
Or do I look at the wrong vehicle?!
Mine is a 04/2023, 2,2L 160 PS w/ digital dash
Or has it moved into the Body Computer?
Thanks Folks 8-)
Re: NEW 2023 Ducato no adjustment of Tire pressure?
You new Ducato probably use the more modern *passive* TPMS. There are no pressure sensors in the wheels. Instead the system uses the ABS systems to detect wheels rotating differently due to low tyre pressures.
Darsh
Post by Darsh »
malibu wrote: 21 Nov 2023, 12:28 Hi everyone,
Thanks Folks 8-)
Is tire pressure adjustment no longer possible? My 04/2023, 2.2L, 160 PS with a digital dash doesn't have a separate listing point in the Vehicles list. Has it shifted to the Body Computer?
check if you have RFHub module in MES. tire pressure control was moved there
Has anybody checked the vehicle's Owner's Handbook?
Any TPMS functions / displays should be documented there, be that for Active or Passive TPMS.
