Fiat 500 proxy error
josesales
Post by josesales »
Hello all, I install uconnect 7" on Fiat500 now cant align proxy. Have this log.
Can someone help me with correct proxy configuration?
Thank you very much for help and support
CAN CONFIGURATION DATA:
4F 80 00 05 00 00 00 00 4F 80 00 05 10 00 00 00 09 00 00 01 10 00 00 00 01 00 00 00 10 00 00 00 00 00 00 00 00 00 00 00
4F 80 00 05 00 00 00 00 09 00 00 04 00 00 00 00 4F 80 00 05 10 00 00 00 09 00 00 04 10 00 00 00 09 00 00 04 00 00 00 00
33 32 31 35 30 30 31 38 33 30 37 4F 55 54 50 55 54 44 4A 49 54 20 16 04 06 4F 80 00 05 00 00 00 00 09 00 00 04 00 00 00 00 01 C2 73 06 FE 00 1C C0 00 00 00 16 00 01 00 94 06 41 01 00 40 00 00 00 75 41 0A 0C 0D 01 80 2E 24 00 00 00 00 31 05 11 00 00 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 9E 00 94 00 22 00 04 88 00 00 20 80 00 00 40 00 01 00 0F 00 00 00 00 01 00 40 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Body Computer Node (BCM/NBC)
Engine Control Node (ECM/NCM)
Dashboard Node (IPC/NQS)
Parking Sensor Node (PAM/NSP)
Airbag Node (NAB/ORC)
(Multiecuscan 4.7R3)
07-11-2023 11:17:17
Fiat 500 1.4 16V T-Jet/MultiAir
Parking Sensor Node (PAM/NSP): Ok
Airbag Node (NAB/ORC): EOL Ok
Entertainment Telematic Node (ETM): Added / EOL Failed
EXECUTING ADJUSTMENT...
PROXI ALIGNMENT PROCEDURE
Writing to module: Entertainment Telematic Node (ETM) FAILED! - Request out of range error
| Byte 148: 00->1C
FAILED TO EXECUTE
Muhib899
Re: Fiat 500 proxy error
Post by Muhib899 »
I need the same help i bought a car that had the interior stolen and the media screen was stolen i bought a secondhand screen but the trip keeps flashing i have tried proxy alignment but keeps failing. I need someone to code the screen to the vehicle. Can someone help i am willing to pay for this.
