Swapping old cluster with TFT problems
Kareem
Post by Kareem »
Hello All
I bought a TFT cluster from 2021 model , to fit it into my 2009 model ,,, yes, I learned the hard way, there are problems due to differences between blue&me and uconnect ,,, however,,, I did install it ,,, did proxy alignment ,, all went good, no more flashing at all ,,, however I have 2 problems
1) odometer didn't change ( kms are set to 21500 however the real should be 87000 ) ,, odo not flashing, however I can't change the milage to the correct value
2) daylights are no more working ,,,, No matter what I did try ,, I can't get the daylights to work
Is there a solution for these two issues ? note that I am planning to change the headunit anyway ( probably will go with the android chinese one that is meant for that model )
Thanks in advance
