ECU Programming date and P0336 error code
LeighF
Post by LeighF »
Good morning
WHen establishing connection with my ECU I have noticed that the ECU Programming date show 00/00/0000. Does this mean the ECUs mapping is gone.
I am receiving a P0336 (Crankshaft Position sensor "A" Circuit Range/Performance) error code. I have replaced the sensor and tested all cables and connectors related to the sensor.
The vehicle starts but idles rough and wont rev above 2000 RPM.
The vehicle is a 2006 Alfa 159 2.2 JTS
Any advice and feedback would be appreciated.
Regards
Leigh
bowdenandymecom
Re: ECU Programming date and P0336 error code
Post by bowdenandymecom »
Did replacement of the sensor clear the P0336?
If not, there must be some other fault causing the error.
What, if any, other errors is MES reporting?
I can't comment on the significance of the strange date.
