DASM failed proxy
fasda1984
DASM failed proxy
Post by fasda1984 »
hello can't do alligment, it fail at DASM ecu. Sure some byte to change in custom proxy.
Follow FESLog . Who can help me? Other retrofit ecu is working fine and i can log in into DASM and read my VIN and other setting. Please Help me.
Lettura dati configurazione CAN...
CAN CONFIGURATION DATA:
4F 0C 40 65 10 00 19 02 02 08 00 00 80 00 00 00 4F 0C 40 65 10 00 19 02 02 08 00 00 80 00 00 00 44 0C 00 60 10 00 00 02 02 08 00 00 80 00 00 00 00 00 00 40 10 00 00 02 00 00 00 00 00 00 00 00
4F 0C 40 65 10 00 19 02 02 08 00 00 80 00 00 00 4B 0C 00 65 10 00 19 02 02 00 00 00 80 00 00 00 4F 0C 40 65 10 00 19 02 02 08 00 00 80 00 00 00 4B 0C 00 65 10 00 19 02 02 00 00 00 80 00 00 00 4B 0C 00 65 10 00 19 00 02 00 00 00 80 00 00 00
30 34 36 32 30 30 33 37 30 33 39 4F 55 54 50 55 54 2D 53 49 54 20 16 07 13 4F 0C 40 65 10 00 19 02 02 08 00 00 80 00 00 00 4B 0C 00 65 10 00 19 02 02 00 00 00 80 00 00 00 43 DD 2F 02 A9 A3 08 6D 74 2B A1 07 48 10 10 0A AB 28 0E FA C0 35 73 14 01 4F 03 34 9D 03 CC 24 03 23 05 00 A0 00 0A 3C 00 00 18 04 00 91 00 5B FA 64 07 ED 05 31 02 01 70 15 3D 89 14 39 00 CF 00 93 18 16 A4 3D 49 00 E3 12 FD 57 80 00 00 B8 FF 3C F0 50 08 30 91 08 20 00 33 00 00 0A 14 00 00 02 00 17 00 C0 00 03 40 18 00 01 13 00 00 00 00 01 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 80 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Body Computer (BCM/NBC)
Controllo motore (ECM/NCM)
Quadro Strumenti (IPC/NQS)
Cambio Automatico/Robotiz. (TCM/NCA/NCR)
Nodo Selettore Cambio (ESM/GSM/NSC)
Driver Assistant System Node (DASM)
Radio Frequency Hub Node (RFHM)
Climatizzatore (HVAC/NCL)
Comfort Seat and Wheel Node (CSWM)
Left Blind Spot Sensor Node (LBSS)
Right Blind Spot Sensor Node (RBSS)
Entertainment multimedia control module (EMCM)
Guida Elettrica (EPS/NGE)
Impianto frenante (ABS/BSM/NFR)
Nodo Sensore Parcheggio (PAM/NSP)
Nodo Air Bag (NAB/ORC)
Nodo Fari Autoadattativi (AFLS/NFA)
Nodo Controllo Corsia (HALF)
(Multiecuscan 5.1)
09/09/2023 08:33:55
Alfa Romeo Giulia 2.2 MultiJet 16V
CAN Setup / PROXI Alignment Procedure (952)
Controllo motore (ECM/NCM): EOL Ok
Quadro Strumenti (IPC/NQS): EOL Ok
Cambio Automatico/Robotiz. (TCM/NCA/NCR): EOL Ok
Nodo Selettore Cambio (ESM/GSM/NSC): Ok
Driver Assistant System Node (DASM): EOL Fallito
Climatizzatore (HVAC/NCL): EOL Ok
Comfort Seat and Wheel Node (CSWM): EOL Ok
Left Blind Spot Sensor Node (LBSS): EOL Ok
Right Blind Spot Sensor Node (RBSS): EOL Ok
Entertainment multimedia control module (EMCM): EOL Ok
Guida Elettrica (EPS/NGE): Ok
Impianto frenante (ABS/BSM/NFR): EOL Ok
Nodo Sensore Parcheggio (PAM/NSP): EOL Ok
Nodo Air Bag (NAB/ORC): EOL Ok
Nodo Fari Autoadattativi (AFLS/NFA): EOL Ok
Nodo Controllo Corsia (HALF): EOL Ok
CUSTOM PROXI NEW DATA:
30 34 36 32 30 30 33 38 35 38 32 4F 55 54 50 55 54 2D 53 49 54 20 16 07 13 4F 0C 40 65 10 00 19 02 02 08 00 00 80 00 00 00 4B 0C 00 65 10 00 19 02 02 00 00 00 80 00 00 00 43 DD 2F 02 A9 A3 08 6D 74 2B A1 07 48 10 10 0A AB 28 0E FA C0 35 73 14 01 4F 03 34 9D 03 CC 24 03 23 05 00 A0 00 0A 3C 00 00 18 04 00 91 00 5B FA 64 07 ED 05 31 02 01 70 15 3D 89 14 39 00 CF 00 93 18 16 A4 3D 49 00 E3 12 FD 57 80 00 00 B8 FF 3C F0 50 08 30 91 08 20 00 33 00 00 0A 14 00 00 02 00 17 00 C0 00 03 40 18 00 01 13 00 00 00 00 01 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 80 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
ESECUZIONE ADEGUAMENTO...
PROCEDURA ALLINEAMENTO PROXI
Scrittura dati configurazione CAN...
Registrazione modulo: Body Computer (BCM/NBC) ESEGUITO!
Registrazione modulo: Controllo motore (ECM/NCM) ESEGUITO!
Registrazione modulo: Quadro Strumenti (IPC/NQS) ESEGUITO!
Registrazione modulo: Cambio Automatico/Robotiz. (TCM/NCA/NCR) ESEGUITO!
Registrazione modulo: Driver Assistant System Node (DASM) FALLITO! - Errore sconosciuto
[102A] errors: Byte 1: 30->CF
Registrazione modulo: Radio Frequency Hub Node (RFHM) ESEGUITO!
Registrazione modulo: Climatizzatore (HVAC/NCL) ESEGUITO!
Registrazione modulo: Entertainment Telematic Node (ETM) ESEGUITO!
Registrazione modulo: Comfort Seat and Wheel Node (CSWM) ESEGUITO!
Registrazione modulo: Left Blind Spot Sensor Node (LBSS) ESEGUITO!
Registrazione modulo: Right Blind Spot Sensor Node (RBSS) ESEGUITO!
Registrazione modulo: Entertainment multimedia control module (EMCM) ESEGUITO!
Registrazione modulo: Impianto frenante (ABS/BSM/NFR) ESEGUITO!
Registrazione modulo: Nodo Sensore Parcheggio (PAM/NSP) ESEGUITO!
Registrazione modulo: Nodo Air Bag (NAB/ORC) ESEGUITO!
Registrazione modulo: Nodo Fari Autoadattativi (AFLS/NFA) ESEGUITO!
Registrazione modulo: Nodo Controllo Corsia (HALF) ESEGUITO!
ESECUZIONE FALLITA
chrener
Re: DASM failed proxy
Post by chrener »
Hi!
What did you do with DASM unit? Or what did you set in proxi?
Was the DASM unit brand new or virginized? Or just used one?
fasda1984
Post by fasda1984 »
After retrofitted body and many other ecu have changed DASM too( FCW radar), all working with old radar but i want to put new radar and it fail in aligment, really strange. It was new and contain my VIN number and calibrated succesfully with brainbee ad mirror procedure. I think some byte to change in proxy but i don't know which byte to customize. Or just a MES 5.1 bug dialogue? I can login in dasm and comunicate with it
