ProxyAlignment Citroen Jumper (Fiat X290)
JohanWinas
Post by JohanWinas »
First of thank you for a great software, works perfect for my needs, but I am uncertain if the proxy alignment is safe to execute.
I have a Citroen Jumper 2015 with the 2.2L Ford Puma engine.
The chassi is the same as a Fiat X290, BCM is identified as a X290 and all modules on the chassi is found.
I use a ELM327 interface modified to behave as with the Yellow cable, connection, scan, fault clearing etc work fine.
For anyone interested I am running multiecuscan under Windows 11 for arm on a Mac M1 with vmware.
For the Engince ECU etc I have the Lexia3 cable and software.
Now to my question/problem.
My cruise control stalk does not work, as soon as its pluged in the green indicator on the dash lights up, no matter what I do on the stalk.
I have verified that the stalk is ok by measuring the circuit etc, it all checks out.
Looking at the BCM via MES I can see that the Cruise control option is enabled, but the Speed limitation function is disabled.
The stalk I have has the Speed limitation function, so I want to change this setting.
Bit of background here, after I bought the van I found that someone must have spilled a CocaCola over the dash, the radio has some issues with corroded traces and I found sticky recidue behind the panels. My guess is that someone replaced the stalk and they did not notice that the original stalk did not have speed limiter, and they fitted a stalk with speed limiter.
If anyone is interested I have the schematics, pictures etc of how the stalk is wired.
What I'm concerned about is that the proxi alignment list my engine as Gasoline (Its a diesel) and the engine type as "2" and gearbox to type as "2".
As these are the values that MCE has read from the BCM I am guessing they are correct, and it would be safe to execute a proxy alignment.
Is it safe for me to exectue a proxy alignment???
This is the proxy data without any changes.
30 38 32 35 30 32 30 32 32 37 31 4F 55 54 50 55 54 44 4A 49 54 20 15 01 27 4B 10 00 0D 10 00 00 00 09 00 00 04 10 00 00 00 83 48 53 08 20 00 7C 20 00 20 00 16 00 00 20 8C 06 0B 02 60 C0 18 56 00 05 00 15 04 00 00 00 00 57 00 20 00 00 32 00 21 01 31 32 00 FF 00 03 00 A0 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 BB 00 00 00 02 00 00 84 12 00 10 00 00 00 30 00 05 00 00 00 00 00 00 0D 00 00 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 1F 00 00 BB 00 00 02 FF
This is the proxy data where I have changed the speed limiter option to enabled, and disabled the headlight washers.
30 38 32 35 30 32 30 32 32 37 31 4F 55 54 50 55 54 44 4A 49 54 20 15 01 27 4B 10 00 0D 10 00 00 00 09 00 00 04 10 00 00 00 83 40 53 08 20 00 7C 20 00 20 00 16 00 00 20 8C 06 0B 02 60 C0 18 56 00 05 00 15 04 00 00 00 00 57 00 20 00 00 32 00 21 03 31 32 00 FF 00 03 00 A0 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 BB 00 00 00 02 00 00 84 12 00 10 00 00 00 30 00 05 00 00 00 00 00 00 0D 00 00 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 1F 00 00 BB 00 00 02 FF
I can see that there is only two bytes that has changed.
And here is the output of a scan:
Body / BCM (Body Control Module)
Body Computer Marelli (290)
ISO Code: BF 83 8F 0D B3
VIN code: VF7YCUMFC12802657
Hardware number: BC250I.0400 - Ver: 04
Software number: 04440007103 - Ver: 0308
Errors found:
U0001-88 - C-CAN - Bus OFF
Airbag / NAB/ORC (Airbag/Occupant Restraint Module)
TRW Airbag MY14
ISO Code: EA 07 58 0D AB
Hardware number: 232450 - Ver: 02
Software number: FD010100 - Ver: 0101
Instrument Panel Marelli
ISO Code: 32 83 EF 0D 86
Hardware number: 50011590001 - Ver: 00
Software number: 04003012820 - Ver: 0900
Dashboard / ETM (Entertainment Telematic Module)
Uconnect Radio/Nav 5"
ISO Code: B5 83 19 0B 31
Hardware number: F.EU.D1.V21 - Ver: 21
Software number: 06.00.35.00 - Ver: 0600
Errors found:
B157A-1A - DAB aerial - Circuit resistance too low/below threshold
Other / PAM/NSP (Parking Sensors Module)
Parking control Bosch
ISO Code: 3E 83 89 86 25
Hardware number: 0263004464 - Ver: 15
Software number: 1.21 - Ver: 0106
chrener
Re: ProxyAlignment Citroen Jumper (Fiat X290)
Post by chrener »
Which CC stalk do you have?
For CC only or with Limiter also?
On some models works only 3-pin stalk with CC and Limiter...
JohanWinas
The stalk I have is a CC with limit function.
And the setting in the body controller for "limit function" is disabled.
But I am uncertain if the proxy alignment is safe to execute on my vehicle.
When a proxy lignment is performed, what happens?
Does it only write to the body controller?
Or does it write to any of the other units as well?
The byte data shown, is this the raw data read from the body controller? And is this what written to the body controller?
omercigerci29
Post by omercigerci29 »
Have you made any progress? I've just tried activating the outdoor temperature sensor, but I haven't been successful.
JohanWinas
I have not made any progress on this, not had the time and did not find any more information on it.
And as this is my daily driver I am not taking any chanses doing something that might go wrong.
What year and make is your van?
