Hello yani. multiecuscan work perfectly on my 159 with elm 327 1.3a and when i make DPF regeneration he work ,start at 3000rpm for +-5min and finish ok.
odometre at last regeneration is ok 0km but obsturation is stay a 70% the same at the begining and continu give up and no reset to 0% or 10% like ecu regeneration .
alfa 159 Helps
Re: alfa 159 Helps
i need your helps yani. i want to buy but with this probleme i'am not interresing
