Faultcode u0184-00 uconnect
Sporting500e
Post by Sporting500e »
I have a faultcode in the uconnect 7 its says u0184-00 lost comminication with radio module .
Uconnect keeps rebooting about every 3 minutes.
And tomtom stays on loading when you start tomtom.
I disconnect the battery for 1 hour
I did factory reset
Nothing works
I connect my old u5 that works fine no problems
Any suggestions thanks,,......
abarthmultijet
Re: Faultcode u0184-00 uconnect
Post by abarthmultijet »
Had a similar case, replacement of the whole unit solved the problem. Don't know if there is another fix for it
ferreira_scb
Post by ferreira_scb »
abarthmultijet wrote: 12 Jul 2023, 21:17 Had a similar case, replacement of the whole unit solved the problem. Don't know if there is another fix for it
I can fix it if you need
abarthmultijet
ferreira_scb wrote: 22 Jul 2023, 13:05
[/quote]
Was not my radio, one of a friend in the eastern europian region. Is it an easy fix?
ferreira_scb
abarthmultijet wrote: 24 Jul 2023, 19:13
[/quote]
Need soldering skills and repair file.
ferreira_scb
[/quote]
Hello mate, not hard I can help you if you need only need remove emmc. Can you add me in whatsapp ?
+351924288993. I also need you help about proxy aligment
