Self-adaptation automatic transmission Alfa Romeo 166
Brainy49
Post by Brainy49 »
I would like to use Multiecuscan to reset the adaptation values on my Alfa Romeo 166 2.4JTDm with AISIN automatic transmission. When I connect to the transmission control unit, there is a function "self-adaptation". Is there anything to consider here, when running the function, so that the transmission adapts properly? For example: Does the motor have to run when executing the function? Is the motor maybe not allowed to run?
Many thanks in advance!
Best regards,
Thomas Ortner
abarthmultijet
Re: Self-adaptation automatic transmission Alfa Romeo 166
Post by abarthmultijet »
MES will give a fault with the text: "Incorrect conditions to execute!" when the right steps are not taken. Usually the right conditions are in the help tab on the right.
