FIAT Ducato without Airbag, retrofit, PROXI Alignment
kaya
Post by kaya »
Hi all,
a good friend of me got a 2.2 HDI Citroën Jumper from 2015 with MANUAL Transmission and a prototype/camper like car from FIAT(Carthago?) with 3.0MJD AUTOMATIC TRANSMISSION.
The Jumper had a blown engine, so he put all wiring loom over to the Jumper chassis from the camper chassis(my14/15 facelift) and swapped 2.2 against 3.0 engine.
Everything works fine for him beside of the Airbag, he did not find the connector to install the airbag ecu, once I investigated both looms and found out that it strictly does not have an Airbag connector.
I removed it from the old loom and added it to the FIAT wiring loom and I can perfectly access the ECU via Multiecuscan, but the PROXI Alignment does fail.
Every time it fails on Airbag Module. Multiecuscan says: Airbag (NAB) - EOL Failed.
In case if I install the BCM of the Jumper, I can perfectly do the PROXI Alignment for AIRBAG with that modified wiring loom, but what does fail in this case is the AUTOMATIC Transmission can't be PROXI aligned.
Some data for an overview:
Citroën Jumper 2015, 2.2 HDI, MANUAL TRANSMISSION - WITH AIRBAG LOOM AND ECU
BCM250I.05
P/N 1386607080
VIN: VF7YDTMDC12887386
FIAT DUCATO 2019, 3.0 MJD, AUTOMATIC TRANSMISSION - NO AIRBAG ECU but RETROFITTED from JUMPER
BCM250I.04
P/N 1374230080
VIN: ZFA25000002497717
Airbag ECU P/N 01375110080 and has a blue LABEL
I need some FIAT experts advice Smile
Now the key question is, do we need a newer Airbag ecu, or can we do manual TELECODING or maybe FLASH newer Software to BCM?
How are software updates done on FIAT cars, which Diag Software?
I have various Diag heads, x431, ELM, FVDI/SVCI, various Programmers like Carprog/xprog/UPA/eeprom readers...MultiECUscan.
Best Wishes
kaya
chrener
Re: FIAT Ducato without Airbag, retrofit, PROXI Alignment
Post by chrener »
Hi!
Just share your proxi configuration
In proxi settings press together Alt+Ctrl+C and copy the tab...
After adding Airbag ECU you have to set airbags config into proxi code..
So how many airbags are in car?
How many pretensioners?
How many seat belt lockers? It means 2 passengers or 3 passengers on front seats?
Jeep Renegade 1.4 MultiAir TURBO 75th Anniversary
kaya
Post by kaya »
Hi chrener,
I connected Airbag ECU and did proxi alignment and it failed again, now I copied the raw content of the configuration as you described.
30 38 32 35 30 31 37 36 38 32 38 4F 55 54 50 55 54 44 4A 49 54 20 13 09 10 4B 1C 00 04 00 00 00 00 09 04 00 04 00 00 00 00 45 00 11 08 B1 00 7C 00 00 00 00 16 00 00 00 0C 06 0A 03 60 C0 02 00 00 00 00 00 00 00 00 00 00 56 00 00 00 00 24 00 32 00 11 34 00 FF 00 09 00 80 30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 07 00 00 00 00 00 00 84 10 00 00 00 00 00 30 00 00 00 00 00 00 00 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 1F 00 00 00 20 00 02 FF
We have driver seat and separately two passengers, we have one driver airbag, we have airbag connector only on driver seat.
I will disconnect and repeat this procedure to gain the raw config again, but I think it will be the same output :)
Looking forward to hear from you to finally finish this car.
EDIT:
Of course I learned thanks to you about thecustom Proxi Alignment and google around:
Heres my LOG:
CAN CONFIGURATION DATA:
4B 1C 00 04 00 00 00 00 4B 1C 00 04 00 00 00 00 49 08 00 04 00 00 00 00 49 08 00 04 00 00 00 00 00 00 00 00 00 00 00 00
4B 1C 00 04 00 00 00 00 09 04 00 04 00 00 00 00 4B 1C 00 04 00 00 00 00 09 04 00 04 00 00 00 00 09 04 00 00 00 00 00 00
Body Computer Node (BCM/NBC)
Engine Control Node (ECM/NCM)
Dashboard Node (IPC/NQS)
Automatic Transmission Node (TCM/NCA/NCR)
Steering Angle Sensor Node (NAS)
Airbag Node (NAB/ORC)
(Multiecuscan 5.1)
01.07.2023 01:32:48
Fiat Ducato (type 290) 3.0 Multijet
CAN Setup / PROXI Alignment Procedure (290)
Automatic Transmission Node (TCM/NCA/NCR): Ok
Steering Angle Sensor Node (NAS): Ok
Airbag Node (NAB/ORC): EOL Failed
EXECUTING ADJUSTMENT...
Engine type
Old value: Type 3/3.0JTD
New value: Type 3/3.0JTD
COMPLETED
Brake lights
Old value: Europe (separate from direction)
New value: Europe (separate from direction)
COMPLETED
PROXI ALIGNMENT PROCEDURE
Writing to module: Airbag Node (NAB/ORC) FAILED! - Request out of range error
   [102A] errors: Byte 68: 00->01
FAILED TO EXECUTE
FAILED TO EXECUTE
Best Wishes
kaya
kaya
Post by kaya »
While i was formatting my message and adding the texts into code brackets, it went trough the proxi alignment, what i did was to change byte 68 from 00 to 01 and redo the alignment :)
Thank you brother for your solution approach.
(Multiecuscan 5.1)
01.07.2023 02:03:45
CUSTOM PROXI NEW DATA:
30 38 32 35 30 31 37 36 38 32 38 4F 55 54 50 55 54 44 4A 49 54 20 13 09 10 4B 1C 00 04 00 00 00 00 09 04 00 04 00 00 00 00 45 00 11 08 B1 00 7C 00 00 00 00 16 00 00 00 0C 06 0A 03 60 C0 02 00 00 00 00 00 4C 00 00 00 00 56 00 00 00 00 24 00 32 00 11 34 00 FF 00 09 00 80 30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 07 00 00 00 00 00 00 84 10 00 00 00 00 00 30 00 00 00 00 00 00 00 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 1F 00 00 00 20 00 02 FF
   [102A] errors: Byte 68: 00->01 | Byte 69: 4C->04
FAILED TO EXECUTE
30 38 32 35 30 31 37 36 38 32 38 4F 55 54 50 55 54 44 4A 49 54 20 13 09 10 4B 1C 00 04 00 00 00 00 09 04 00 04 00 00 00 00 45 00 11 08 B1 00 7C 00 00 00 00 16 00 00 00 0C 06 0A 03 60 C0 02 00 00 00 00 01 00 00 00 00 00 56 00 00 00 00 24 00 32 00 11 34 00 FF 00 09 00 80 30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 07 00 00 00 00 00 00 84 10 00 00 00 00 00 30 00 00 00 00 00 00 00 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 1F 00 00 00 20 00 02 FF
COMPLETED
kaya
Post by kaya »
Hey there,
im sorry for spaming but I thought I show the people how I proceeded.
The airbag error is gone, that is fine but there are so many other problems we had or still have.
I could correct the ABS/ESC coding aswell, we had to change the buttons in the center.
The headlamp leveling does work also now and we also have remaining mileage on the dashboard.
What does not work as for now is that we can not set the date and time, we cant access the dashboards settings menu via the MODE button as it does not react.
The time is blinking in the dashboard.
As for the average consumption, we need to test if that does work again now.
I guess these problems are relying to still some proxi coding issue, as a few ECUs have different kind of errors.
The current custom proxi alignment is this:
30 38 32 35 30 31 37 36 38 32 38 4F 55 54 50 55 54 44 4A 49 54 20 13 09 10 4B 1C 00 04 00 00 00 00 09 04 00 04 00 00 00 00 05 40 11 08 B1 00 7C 00 00 00 00 16 00 00 00 0C 06 0A 03 60 C0 02 00 00 00 00 01 00 00 00 00 00 56 00 00 00 00 34 00 42 00 11 34 00 FF 00 09 00 80 30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 07 00 00 00 00 00 00 84 10 00 00 00 00 00 30 00 00 00 00 00 00 00 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 1F 00 00 00 20 00 02 FF
DTCS:
Engine / ECM
Bosch EDC17CP52 CF5/CF5+/EOBD Diesel Injection (3.0)
ISO Code: B3 86 9E 8C 38
Hardware number: 0281030431 - Ver: 00
Software number: 1037529156 - Ver: 6042
Gearbox / TCM/NCA/NCR (Automatic Transmission)
Marelli SELESPEED CFC348 Automatic Gearbox
ISO Code: BC 07 A2 8A C4
Hardware number: CFC 348F.18 - Ver: 00
Software number: FGC16ZMQ - Ver: 0000
Errors found:
P0710-86 - Temperature (from CAN) - Signal/message invalid
Body Computer Marelli (290)
ISO Code: BF 83 8F 0D B3
VIN code: ZFA25000002497717
Hardware number: BC250I.0400 - Ver: 04
Software number: 04440007100 - Ver: 0102
Errors found:
U1706-86 - Brake system (NFR) - Signal/message invalid
U1701-86 - Engine control (NCM) - Signal/message invalid
U0001-87 - C-CAN - Missing message
B1011-18 - Number plate lights - Current too low/below threshold
B1008-15 - Right direction indicators - Short to +V or open circuit
After putting yellow adapter and rescanning:
Body / BCM (Body Control Module)
Errors found:
U0019-01 - B-CAN line - General electrical failure
Airbag / NAB/ORC (Airbag/Occupant Restraint Module)
TRW Airbag MY14
ISO Code: EA 07 CD 0D 20
Hardware number: 232450 - Ver: F1
Software number: FD010100 - Ver: 0101
Instrument Panel Marelli
ISO Code: 32 83 70 0D 07
Hardware number: 50011220002 - Ver: 00
Software number: 04003012904 - Ver: 0400
Errors found:
U1700-86 - No Body Computer - Signal/message invalid
U1706-87 - NFR Node absent - Missing message
Climate control / HVAC (Heating Ventilation Air Conditioning)
Denso climate control (Single zone)
ISO Code: 34 83 1C 89 31
Hardware number: ANR97A107A - Ver: 01
Software number: 5AA967EA - Ver: 0002
Errors found:
U0019-87 - CAN line - Missing message
Thank you for your assistance and understanding.
Best Regards
kaya
