Alfa 159 Injector programming
Posted: 18 May 2023, 19:49
Hi there.
First Post so sorry if its a daft question.
I've got a fully registered copy of MultiECUscan and have a problem.
I purchased 5 new (refurbished) injectors for my 2.4 Alfa 159. All fitted but when I try to enter the coding number I can code 2 of the injectors but the other 3 won't work.
I can enter the code number from the 2 that will work into any cylinder I like.
I've tried both cables with the same results.
Thinking it was an injector issue I sent them back, they were tested and sent back as all good. I suspect there's an issue with the injectors but I need to confirm it's not the vehicle.
Hopefully I'm not missing something obvious with the software?
