PROXI - Enabing Xenons Alfa Stelvio
frankp2112
Post by frankp2112 »
I have been trying to enable Xenons on my Stelvio.
I have changed the setting in the MES and successfully run a proxi config.
However the DRL and indicators are not working - I have checked the light and it ok and the connector is fine.
I can only assume that the change is not taking affect after the proxi and the BCM is not connecting to the LEDS
Any suggestions on what I may have missed?
Frank
Re: PROXI - Enabing Xenons Alfa Stelvio
wiring is different between halogen and xenon headlights
frankp2112
The wiring is the same
the xenon lights work fine.
The LED's do not when when I checked the voltage at the pin it drops when the LEDS are plugged in.
I suspect the BCM is not picking up the changes but this is me having a guess.
Frank
chrener
Post by chrener »
Hi!
Wiring is not same!
You have to add 2 wires for both lamps to activate DRL and for correct function of turning lights...
Then you have to change proxi settings...
Good luck!
frankp2112
Can you elaborate about the wires?
I have checked the power at the connectors and can see power there.
I have attached the picture of the connector
My understanding is these are the connectors
1– Low beam positive control . 8 – NA.
2 – DRL/side Marker Lamp Positive Control 9 – Vertical Adjustment Motor Positive Control
3 – DRL/side Marker Lamp Signal 10 – NA.
4 – Direction Indicator Lamp Positive Control 11 – NA.
5 – High Beam Positive Control 12 – Vertical Adjustment Motor Signal
6 – NA. 13 – Ground
7 – NA. 14 – Ground
Also what proxi change is there I can only see the xenon and the shutter ti chnage?
Frank
