Fiat 500 2015 help proxy
barto46
Post by barto46 »
Hi guys
I need your help
1: I have a Fiat 500, year 2015 and I change Uconnect 5 VP2 312 NAV with Uconnect 5 VP2 312 without nava and being Proxy Alignment it won't let me, it gives an error and flashes the KM
#: I understand that it won't let me because the GPS antenna is not connected
#:As I mount Uconnect 5 from another car the radio has another VIN
I leave the Bytes below if someone can help me configure
Thank you
33 32 31 35 30 30 31 35 36 31 37 4F 55 54 50 55 54 44 4A 49 54 20 15 09 26 4F 84 00 04 10 00 00 00 09 00 00 04 10 00 00 00 81 C2 71 06 FE 00 1C C0 00 00 00 16 00 01 00 94 06 41 01 00 40 00 00 00 75 41 0A 0C 0D 01 80 2E 24 00 00 00 00 31 05 11 00 00 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B1 00 94 00 22 00 04 88 02 00 20 80 00 00 44 00 D1 00 0F 00 00 00 00 01 00 60 01
Thank you
barto46
Re: Fiat 500 2015 help proxy
Post by barto46 »
Hi guys
Can someone help me with Proxy Alignment
thanks for your help
fiatguy88
Post by fiatguy88 »
Do you have the security code for the replacement radio?
barto46
Post by barto46 »
fiatguy88 wrote: 08 May 2023, 02:29 Do you have the security code for the replacement radio?
Hello fiatguy88
1: Yes I have the radio code
2: Thanks for your help
I can't do Proxy Alignment, the new radio doesn't have a gps antenna and I don't know which is the bytes to modify
I appreciate if you can help me
barto46 wrote: 24 Apr 2023, 05:36 Hi guys
I need your help
Thank you
Thank you
posting your failed proxi log always helps. as for now try this:
33 32 31 35 30 30 31 35 36 31 37 4F 55 54 50 55 54 44 4A 49 54 20 15 09 26 4F 84 00 04 10 00 00 00 09 00 00 04 10 00 00 00 81 C2 71 06 FE 00 1C C0 00 00 00 16 00 01 00 94 06 41 01 00 40 00 00 00 75 41 0A 0C 0D 01 80 2E 24 00 00 00 00 31 05 11 00 00 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B1 00 94 00 22 00 04 88 02 00 20 80 00 00 40 00 91 00 0F 00 00 00 00 01 00 60 01
barto46
Post by barto46 »
hi shpuncik
1: This week I'll confirm (I don't have the car right now)
Thanks,Thanks
barto46
Post by barto46 »
shpuncik wrote: 08 May 2023, 14:08
I need your help
Thank you
Thank you
hi shpuncik
1:With the new bytes modified by you
# It does not work, it continues the same flashes the Km
