Hex code for proxy alignment
Cyanigosa
Post by Cyanigosa »
Hi Guys
I've put this in the General section also, but have had no help as of yet. So I've put it here as well with the correct information and re worded title.
Hay all just been through the other posts and was unsure what information you guys my need so here goes (if it helps) . Fiat Ducato 250 multijet 2014.
I think the old radio was a uconnect 3 but I'm not sure, as the van is a motorhome they replaced the radio with a vp2 set with Nav and bluetooth but no DAB the radio works perfectly as too does the bluetooth but i have the flashing Mileage as normal the proxy does not work. It comes up with an, added / error so the mileage still flashes. I've looked and cannot figure out how read this code or what to change to get this mileage thing sorted, if there is anyone out there that could help that would be great. Thanks
30 38 32 35 30 32 30 36 33 34 32 4F 55 54 50 55 54 44 4A 49 54 20 14 06 09 4B 00 00 04 10 00 00 00 09 00 00 04 10 00 00 00 11 40 53 08 B1 00 7C 00 00 00 00 26 00 00 00 8C 06 0B 02 60 C0 12 50 00 05 00 05 04 00 00 00 00 56 00 00 00 00 12 10 42 03 11 24 00 FF 00 05 00 80 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 00 00 00 01 00 00 85 12 00 04 00 00 00 40 00 01 00 00 00 00 00 00 01 00 00 00 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 1F 00 00 20 00 00 02 FF
shelby1
Re: Hex code for proxy alignment
Post by shelby1 »
hi mate, this maybe worth a try,
change byte 121 from 40 to 44
then do proxy again, hope it works...........
Cyanigosa
Post by Cyanigosa »
Hi Shelby1, put this on the other forum too, I tried and changed the code from 40 to 44 the radio that was there which was missing has now vanished. the navi has changed it had added/ EOL error the added has now gone but it just says EOL error and the milage is still flashing :)
chrener
Post by chrener »
Is radio VP2 250 type?
