Uconnect 5 with DAB, Proxy Alignment
Posted: 09 Apr 2023, 16:05
Hi guys
1: I have a Fiat 500L year 2016 that has uconnect 5 with gps and without DAB
2: Now change the uconnect 5 that did not work for uconnect 5 with gps and DAB the dab is not connected (it is the same,but with DAB)
#When doing Proxy Alignment so that the Km does not flash,
can't, it gives an error
#Entering radio module gives these errors:
B157A-13 DAB erial (it is normal, it is not connected)
B223B-00 Incorrect configuration
# I think that because of the DAB, since it is not connected, it does not allow Proxy Alignment
3: I understand that Proxy Alignment can be done by modifying some Bytes
# I leave the Bytes if someone can help me
I have Multiecuscan 5.1 and USB OBD-Protect Interface
Thank you
My current proxy is:
33 31 33 33 30 30 32 30 37 34 34 4F 55 54 50 55 54 2D 53 49 54 20 15 12 08 4F 04 00 05 10 00 00 00 09 04 00 05 10 00 00 00 A7 C7 71 07 8F 02 37 10 31 20 00 06 00 07 08 8C 06 15 01 28 C0 00 B1 01 35 41 0A 0C 0D 00 80 1E 35 00 00 00 00 32 00 21 03 10 23 16 00 74 20 05 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B1 00 00 00 00 00 00 80 12 00 10 80 00 00 41 00 11 00 00 00 00 49 00 01 00 00 00
Thank you
