Uconnect 5 with DAB, Proxy Alignment
barto46
Post by barto46 »
Hi guys
1: I have a Fiat 500L year 2016 that has uconnect 5 with gps and without DAB
2: Now change the uconnect 5 that did not work for uconnect 5 with gps and DAB the dab is not connected (it is the same,but with DAB)
#When doing Proxy Alignment so that the Km does not flash,
can't, it gives an error
#Entering radio module gives these errors:
B157A-13 DAB erial (it is normal, it is not connected)
B223B-00 Incorrect configuration
# I think that because of the DAB, since it is not connected, it does not allow Proxy Alignment
3: I understand that Proxy Alignment can be done by modifying some Bytes
# I leave the Bytes if someone can help me
I have Multiecuscan 5.1 and USB OBD-Protect Interface
Thank you
My current proxy is:
33 31 33 33 30 30 32 30 37 34 34 4F 55 54 50 55 54 2D 53 49 54 20 15 12 08 4F 04 00 05 10 00 00 00 09 04 00 05 10 00 00 00 A7 C7 71 07 8F 02 37 10 31 20 00 06 00 07 08 8C 06 15 01 28 C0 00 B1 01 35 41 0A 0C 0D 00 80 1E 35 00 00 00 00 32 00 21 03 10 23 16 00 74 20 05 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B1 00 00 00 00 00 00 80 12 00 10 80 00 00 41 00 11 00 00 00 00 49 00 01 00 00 00
Re: Uconnect 5 with DAB, Proxy Alignment
try changing byte 123 from "11" to "15". missing DAB aerial connection only gives error. of course to have DAB reception you'll still need to install DAB aerial - either OEM or aftermarket.
barto46
Post by barto46 »
shpuncik wrote: 10 Apr 2023, 21:57 try changing byte 123 from "11" to "15". missing DAB aerial connection only gives error. of course to have DAB reception you'll still need to install DAB aerial - either OEM or aftermarket.
Hello shpuncik
Thanks for your help (thanks a lot)
Ok change byte 123 from "11" to "15"
1: in case it doesn't work with this configuration, what byte can I try to change??? to try
2: Next week I'll confirm if it works (I don't have the car right now)
Thank you
shelby1
Post by shelby1 »
try changing byte 123 to D5 and not C5 like i did and it all works
barto46
Post by barto46 »
shelby1 wrote: 23 Apr 2023, 14:33 try changing byte 123 to D5 and not C5 like i did and it all works
hi shelby1
Thanks for your information
At the moment I do not have the car, when I have it I will inform you
thanks for your help
