Uni Air actuator dispersion correction Panda 3
Ek52
Post by Ek52 »
I've got a 2016 panda 1.2. IAW 9gf CF6 ECM. Trying to do a phonic wheel reset (failed, poss due to limp mode, max 4500rpm). But I see the procedure recommends executing the UniAir actuator dispersion correction procedure after the Phonic wheel learn reset. Does anybody know where I can find this please?
Thanks very much
Re: Uni Air actuator dispersion correction Panda 3
The Uni-air correction is for the Twinair/Multiair engines only. Your 1.2 is not of this type. If you had the Panda 0.9 Twinair then you would find the correction under Adjustments for the engine ECU.
apwdr
Post by apwdr »
I have 500X 1.4 multiair and also don't see the UniAir actuator dispersion correction in the Engine module.
500X 1.4L Pop 2015 manual
mark.boudreau
Post by mark.boudreau »
So the Alfa Giulia 2.0 doesn't have the uni air dispersion correction either? Thanks
