Can i run a Proxi Alignment with this error code?
Posted: 17 Feb 2023, 09:15
by smurphy661
I will be replacing my airbag ECU and then need to run a proxi alignment to match it to my car. However I have a separate error code 'U0422 - Inertia Function' that shows up - this error code has been on the car since i bought it about 9 years ago and doesn't seem to effect anything. This error code has nothing to do with the airbags.
If I replace the airbag ECU and clear the airbag error codes and run a Proxi Alginment, will it work if the U0422 error code is still there?
Re: Can i run a Proxi Alignment with this error code?
Posted: 22 Feb 2023, 22:00
by abarthmultijet
My experience is that you really need 0 faults when performing a proxy allignment. Sometimes the allignment still works but it will always say that the allignment has failed.
Posted: 26 Feb 2023, 10:10
by chrener
Dont worry run proxi alignment...
Posted: 01 Mar 2023, 15:41
by Collect1ve
abarthmultijet wrote: 22 Feb 2023, 22:00 My experience is that you really need 0 faults when performing a proxy allignment. Sometimes the allignment still works but it will always say that the allignment has failed.
Hi mate I'm looking to PM you about a Proxi alignment procedure for a Fiat 500, reading through many of your replies with people labelling you "as the god of UConnect" :lol: if you could PM me or let me know where I can contact you that'd be great
Thank you very much
Posted: 01 Mar 2023, 20:27
by abarthmultijet
Collect1ve wrote: 01 Mar 2023, 15:41
Thank you very much
You can pm me if you like, or ask your question here so that other people can read it and get some support from it.
