I will be replacing my airbag ECU and then need to run a proxi alignment to match it to my car. However I have a separate error code 'U0422 - Inertia Function' that shows up - this error code has been on the car since i bought it about 9 years ago and doesn't seem to effect anything. This error code has nothing to do with the airbags.
If I replace the airbag ECU and clear the airbag error codes and run a Proxi Alginment, will it work if the U0422 error code is still there?
Can i run a Proxi Alignment with this error code?
smurphy661
abarthmultijet
Re: Can i run a Proxi Alignment with this error code?
My experience is that you really need 0 faults when performing a proxy allignment. Sometimes the allignment still works but it will always say that the allignment has failed.
Dont worry run proxi alignment...
Collect1ve
Hi mate I'm looking to PM you about a Proxi alignment procedure for a Fiat 500, reading through many of your replies with people labelling you "as the god of UConnect"abarthmultijet wrote: ↑22 Feb 2023, 22:00 My experience is that you really need 0 faults when performing a proxy allignment. Sometimes the allignment still works but it will always say that the allignment has failed.
Thank you very much
abarthmultijet
Collect1ve wrote: ↑01 Mar 2023, 15:41
Hi mate I'm looking to PM you about a Proxi alignment procedure for a Fiat 500, reading through many of your replies with people labelling you "as the god of UConnect"if you could PM me or let me know where I can contact you that'd be great
Thank you very much
You can pm me if you like, or ask your question here so that other people can read it and get some support from it.
