500x 2018 bypass
brufoloso
500x 2018 bypass
Post by brufoloso »
hi, how to mount the bypass module for 500x, then I would like to know if the battery change can be reset? thank you
chrener
Re: 500x 2018 bypass
Post by chrener »
SGW module is above the brake on the left side of steering column support. Up almost under dashboard...
If you have clutch pedal you have to disconnect and remove BCM module from its support frame...
If you have automatic transmission there is no problem...
Attention!!! Everything is so sharp!
EDIT:
After change battery reset is not needed...
