Help, Proxy breaks with timout in Fahrertühr (NPG)
Pazuro
Post by Pazuro »
Need help to fix Proxi
MY car FIAT TIPO 1,4 POP start and stop and ucoonect Radio (NOT 5" or 7") without nav and dab
Proxy breaks after changing Radio, do this because the odo is flashing
everthing seems to be good, but after changing to adapter blue proxy breaks with timeout, is there a way to skip node Fahrertür (NPG) ?
Can anyone Help please ?
here is the log
Lese CAN Konfigurationsdaten ...
CAN CONFIGURATION DATA:
6F 04 00 05 00 00 00 00 00 00 00 00 00 00 00 00 4F 05 00 05 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00
6F 04 00 05 00 00 00 00 00 00 00 00 00 00 00 00 6F 04 00 05 00 00 00 00 00 00 00 00 00 00 00 00 4F 05 00 05 00 00 00 00 00 00 00 00 00 00 00 00 4F 05 00 05 00 00 00 00 00 00 00 00 00 00 00 00 4F 04 00 05 00 00 00 00 00 00 00 00 00 00 00 00
33 36 33 35 36 31 30 34 39 37 36 4F 55 54 50 55 54 44 4A 49 54 20 20 02 03 6F 04 00 05 00 00 00 00 00 00 00 00 00 00 00 00 6F 04 00 05 00 00 00 00 00 00 00 00 00 00 00 00 51 F9 04 01 A4 10 07 87 A0 29 02 07 42 10 00 03 A3 1E 04 01 01 35 63 14 00 4F 03 34 00 83 08 00 3D 00 01 00 80 00 00 00 00 00 30 81 00 25 02 5A 00 20 00 A5 00 41 00 01 A3 17 00 40 00 01 00 C0 00 81 00 12 00 00 49 00 01 14 50 42 00 00 00 01 00 00 70 00 02 1C 80 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 80
Body Computer (BCM/NBC)
Motorsteuerung (ECM/NCM)
Elektrische Lenkung (EPS/NGE)
Instrumententafel (IPC/NQS)
Bremsanlage (ABS/BSM/NFR)
Knoten Parksensor (PAM/NSP)
Knoten Airbag (NAB/ORC)
Rundfunkempfänger (NRR)
Fahrertür (NPG)
Klimaanlage (HVAC/NCL)
(Multiecuscan 5.0)
07.01.2023 11:22:42
Fiat Tipo 2015 1.4 16V
CAN Setup / PROXI Alignment Procedure (356)
Motorsteuerung (ECM/NCM): EOL Ok
Elektrische Lenkung (EPS/NGE): EOL Ok
Instrumententafel (IPC/NQS): EOL Ok
Bremsanlage (ABS/BSM/NFR): EOL Ok
Knoten Parksensor (PAM/NSP): EOL Ok
Knoten Airbag (NAB/ORC): EOL Ok
Rundfunkempfänger (NRR): Entfernt
Fahrertür (NPG): Neue / EOL Fehler
Klimaanlage (HVAC/NCL): EOL Ok
AUSFÜHREN EINSTELLUNG ...
PROZEDUR PROXI-AUSRICHTUNG
Schreibe CAN konfigurations Daten ...
Schreiben des Moduls: Body Computer (BCM/NBC) ERFOLGREICH!
Schreiben des Moduls: Motorsteuerung (ECM/NCM) ERFOLGREICH!
Schreiben des Moduls: Elektrische Lenkung (EPS/NGE) ERFOLGREICH!
Schreiben des Moduls: Instrumententafel (IPC/NQS) ERFOLGREICH!
Schreiben des Moduls: Bremsanlage (ABS/BSM/NFR) ERFOLGREICH!
Schreiben des Moduls: Knoten Parksensor (PAM/NSP) ERFOLGREICH!
Schreiben des Moduls: Knoten Airbag (NAB/ORC) ERFOLGREICH!
Schreiben des Moduls: Fahrertür (NPG) FEHLERHAFT! - Timeout error
Schreiben des Moduls: Klimaanlage (HVAC/NCL) ERFOLGREICH!
FEHLER BEIM AUSFÜHREN
Raeding BCM
(Multiecuscan 5.0)
07.01.2023 11:14:09
Body Computer Marelli (356)
ISO-Code: 00 00 60 C4 14
Code V.I.N.: ZFA356
Seriennummer ECU: TD857023001X
FIAT-Zeichnngsnummer: 52133712
Hardware-Nummer: 356HL2EU611
Hardware-Version: 06
Software-Nummer: 28657507
Software-Version: 2814
Zulassungsnummer: 0777
Betriebszeit (EEPROM): 47880
Betriebsdauer: 47882
( don´t want to wrote whol VIN and and serial)
First reading Proxi:
Re: Help, Proxy breaks with timout in Fahrertühr (NPG)
have you tried using older MES version? most likely it's bug in 5.0 because I can't see Tipo having driver's door module. send report to MES support too.
Pazuro
Post by Pazuro »
No just with 5.0
Works older version with same license as 5.0?
Because i only registered to 5.0 this year.
Thx for answering.
Pazuro wrote: 20 Jan 2023, 07:31 No just with 5.0
Thx for answering.
I don't know that - you'll have to try it yourself. if no luck just contact support.
Pazuro
Post by Pazuro »
it is not working,
wrong license key,
ok, so i will do another try tommorrow and send report to server.
I hope they make a special aligment procedure without node Driver Door (NPG) for POP Series (perhaps is just a bug)
or they can tell me a way how i can fix this , for example by changing specially bytes
My canbus adapter (ACV 42SFA020) with Pioneer AVH-A240DAB is working but odo flashes, If anyone has another idea how
to fix without Proxi Algnment i will be happy.
I think about of installing Old Radio Parallel and hide it after the glove box.
Sry for my terrible english, my mother tongue is german, but there is no german board in this forum ):
Thx for tips
have you tried disconnecting your Pioneer with canbus adapter, do proxi and connect back Pioneer?
Pazuro
Post by Pazuro »
yes i did,
Without canbus proxialgignment works:
Fahrertür (NPG) EOL OK and MES dont want to write to it
but bc does not work after that
and with canbus adapter,
Fahrertür Neue/EolFehl
doing proxi , MES want to writre in Modul Fahretür and then after putting the blue adapter in, Message Timeout
Clima modul after that, is ok
so i do a costum proxi and wrote the first proxi (first scan as i had installed MES) out of the log, and do the proxi without blue adapter, turn ignation of wait for 1 min and the bcm works.
but odo is flashing, Caninfo shows me EOL Fehler Fahretür in red
I ordered another Canbus adapter from dietz now, is uni and programmable .
https://www.dietzshop.de/de/can-bus-lenkradfernbedienung-fuer-250-fahrzeuge-a0.html
I hope this will fix the problem
but now i have to wait e few days.....
Pazuro
Post by Pazuro »
for info:
This the proxi without adapter
4F 04 00 05 00 00 00 00 00 00 00 00 00 00 00 00 4F 04 00 05 00 00 00 00 00 00 00 00 00 00 00 00 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
4F 04 00 05 00 00 00 00 00 00 00 00 00 00 00 00 4F 04 00 05 00 00 00 00 00 00 00 00 00 00 00 00 4F 04 00 05 00 00 00 00 00 00 00 00 00 00 00 00 4F 04 00 05 00 00 00 00 00 00 00 00 00 00 00 00 4F 04 00 05 00 00 00 00 00 00 00 00 00 00 00 00
33 36 33 35 36 31 31 36 31 34 36 4F 55 54 50 55 54 44 4A 49 54 20 20 02 03 4F 04 00 05 00 00 00 00 00 00 00 00 00 00 00 00 4F 04 00 05 00 00 00 00 00 00 00 00 00 00 00 00 51 F9 04 01 A4 10 07 87 A0 29 02 07 42 10 00 03 A3 1E 04 01 01 35 63 14 00 4F 03 34 00 83 08 00 3D 00 01 00 80 00 00 00 00 00 30 81 00 25 02 5A 00 07 00 A5 00 41 00 01 A3 17 00 40 00 01 00 C0 00 81 00 12 00 00 49 00 01 14 50 42 00 00 00 01 00 00 70 00 02 1C 80 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 80
(Multiecuscan 5.0)
22.01.2023 14:28:05
