Ad-Blue remote start
OFF.PAVAN
Post by OFF.PAVAN »
hi
Anybody have dobe the activation of remote strat on adblue giulia?
chrener
Re: Ad-Blue remote start
Post by chrener »
Hi!
I tried to activate it. Coding key and proxi with sucess...
But!
Car after puhing a start button wakes up, turnlights blinks twice as ussualy and starts some relay ticking... Thats all... Engine never started...
Any solution?
Block Urea in ECU or what?
OFF.PAVAN
Post by OFF.PAVAN »
chrener wrote: 21 Dec 2022, 14:07 Hi!
But!
Any solution?
I have the Same problem and take this DTCs
BCM U1736-87 ETM (Modulo telematico intrattenimento) - Messaggio
mancante
Memorizzato
BCM U1736-86 ETM (Modulo telematico intrattenimento) - Segnale non
valido
Memorizzato
BCM B10AA-4A Controllo configurazione non riuscito - Componente
installato non corretto
Attivo
HVAC U1724-87 Modulo telematico di intrattenimento (ETM) - messaggio
mancante
Memorizzato
IPC U1736-86 ETM (Modulo telematico intrattenimento) - Segnale non
valido
Memorizzato
IPC U1736-87 ETM (Modulo telematico intrattenimento) - Messaggio
mancante
Memorizzato
ETM U0010-87 BH CAN - Messaggio mancante Memorizzato
RFH B1040-64 Informazioni stato modalità operativa 1 - Segnale non
plausibile
Memorizzato
ACC C141C-86 Anomalia comunicazione CAN privata videocamera -
Segnale non valido
Memorizzato
this is my data:
30 34 36 32 30 30 33 30 36 39 38 4F 55 54 50 55 54 2D 53 49 54 20 19 11 22 4F 0C 40 45 10 02 00 02 02 08 00 00 80 00 00 00 4B 0C 00 45 10 00 00 02 02 00 00 00 80 00 00 00 43 59 2F 02 A8 03 07 F3 14 2B 81 07 40 10 10 0A A3 28 04 F2 00 35 73 14 01 4F 03 34 18 03 A8 24 19 23 07 00 A0 00 0A 3C 00 00 19 24 00 01 00 5B FA 64 06 ED 05 21 00 01 70 15 3D 81 00 01 00 CA 00 B7 00 11 00 3D 49 01 03 12 F8 47 A0 00 00 C1 00 2D F0 20 04 1A 89 0A 00 00 00 00 00 0A 14 00 00 00 00 35 00 00 01 03 00 1A 00 01 10 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
chrener
Post by chrener »
Did you activate Remote start?
Because in your proxi isnt activated...
try this:
30 34 36 32 30 30 33 30 36 39 38 4F 55 54 50 55 54 2D 53 49 54 20 19 11 22 4F 0C 40 45 10 02 00 02 02 08 00 00 80 00 00 00 4B 0C 00 45 10 00 00 02 02 00 00 00 80 00 00 00 43 59 2F 02 A8 03 07 F3 14 2B 81 07 40 10 10 0A A3 28 04 F2 00 35 73 14 01 4F 03 34 18 03 A8 24 19 23 07 00 A0 00 0A 3C 00 00 19 24 00 01 00 5B FA 64 07 ED 05 21 00 01 70 15 3D 81 00 01 00 CA 00 B7 00 11 80 3D 49 01 03 12 F8 47 A0 00 00 C1 00 2D F0 20 04 1A 89 0A 00 00 00 00 00 0A 14 00 00 00 00 35 00 00 01 03 00 1A 00 01 10 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
OFF.PAVAN
Post by OFF.PAVAN »
yes it is the start data without change, i set bite_108 Value 07 and normaly works
rachid760
Post by rachid760 »
Ciao. Qualcuno è riuscito a risolvere il problema di avviamento su AD-BLUE ?
abarthmultijet
Post by abarthmultijet »
As far is I am informed it is impossible to to add remote start to an adblue Giulia.
