MultiECU uconnect 7" / PROXI Alignment Procedure
malcscer
Post by malcscer »
I am about to do some proxy alignment on my 2017 Fiat 500 Uconnect 7'. (UK model)
Kindly can you help me choose which option shall I select on On MultiECUscan version 5 since it is only listed for 'US models with Uconnect only', while on multiECUscan version 4.6 the option,' Models with Uconnect' is available. (attached screenshots)
https://drive.google.com/file/d/1M1pp3KF-KRMBmA4i2w10MXUTmadqe9Js/view?usp=sharing
https://drive.google.com/file/d/1lhg1vFLsGFCmpPwVqakWBHaR6bTKtfVR/view?usp=sharing
Regards
Re: MultiECU uconnect 7" / PROXI Alignment Procedure
Just use 500 2014+ PROXI
uConnect 5" and 7" are listed/supported in the Dashboard.
chrener
Post by chrener »
malcscer wrote: 29 Nov 2022, 08:48 I am about to do some proxy alignment on my 2017 Fiat 500 Uconnect 7'. (UK model)
Regards
Hi!
If your car is MY2017 than set Proxi alignment procedure 2014+... US models has different proxi settings with liitle bug on ETM/CTM...
malcscer
Post by malcscer »
Thanks all for your reply. Mine is a 500 2017 with 7' Uconnect. So to be clearer since this is my first time using multiECU. I need to align proxy to activate Apple & Android CARPLAY to my 7' Uconnect head unit.
On MultiECU Version 5, I shall select FIAT 500. Then from system options I select 'DASHBOARD' - OR - BODY ?
Zouzz99
Post by Zouzz99 »
Did you manage to activate carplay?
I have a similar situation.
I've got an Abarth and want to activate carplay, but to do the proxi alignment I've got US models with Uconnect only.
Did you end up choosing the option that says 2014+?
