DNA TYPE 2 FAIL
OFF.PAVAN
DNA TYPE 2 FAIL
Post by OFF.PAVAN »
hi, i try to set type 2 on dna to activate the race mode but, i had very lot of problem becouse giulia my 2020 after proxy alliniament, ECM impossible to allineate and pulse km in IPC, i try alos with witech2 original and DOSENT do the total recofiguration and send me the error in BCM B-0001 installed componet not correct, i have to rewrtite the proxy by altrgr-con MES with the copy i after do but also need withec proxy alliniamnet and now TBM2 text me a error message: sos call
i do de update and now works good, 4H to reprogarma TBM2
is possible to my 2020 Giuia set dna\race?
i try alos single proxi set by witech2( to ECM and ABS)BUT FAIL
39 39 36 32 30 31 35 37 31 35 38 4F 55 54 50 55 54 2D 53 49 54 20 20 01 20 4F 0C 40 45 18 02 19 02 0A 08 00 00 80 00 00 00 4F 0C 00 45 18 00 19 02 0A 00 00 00 80 00 00 00 43 59 2F 02 A9 83 07 F3 34 2B A1 07 40 10 10 0A AB 28 04 F2 00 35 73 14 01 4F 03 34 0D 83 AC 48 06 43 05 00 A0 00 0A 3C 00 00 19 24 01 01 02 5B FA 64 06 ED 05 31 00 01 70 1D 3D 81 10 01 00 CE 00 B7 10 14 44 3D 49 03 03 12 F9 57 A0 00 00 01 00 2F F2 20 04 18 91 0A 00 00 00 00 00 0A 14 00 00 00 00 35 00 40 01 03 00 18 00 08 23 0D 00 00 58 03 00 01 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Re: DNA TYPE 2 FAIL
where is proxi log? which MES version?
if proxi fails, do it one more time, if fails again give it another try - might sometimes need 5-6 passes. still no go, use different MES version.
OFF.PAVAN
Re: DNA TYPE 2 FAIL
Post by OFF.PAVAN »
shpuncik wrote: 08 Nov 2022, 13:54 where is proxi log? which MES version?
I HAVE 5.0 MES VERSION
Lettura dati configurazione CAN...
CAN CONFIGURATION DATA:
4F 0C 40 45 18 02 19 02 0A 08 00 00 80 00 00 00 4F 0C 40 45 18 02 19 02 0A 08 00 00 80 00 00 00 00 00 00 40 18 00 00 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
4F 0C 40 45 18 02 19 02 0A 08 00 00 80 00 00 00 4F 0C 00 45 18 00 19 02 0A 00 00 00 80 00 00 00 4F 0C 40 45 18 02 19 02 0A 08 00 00 80 00 00 00 4F 0C 00 45 18 00 19 02 0A 00 00 00 80 00 00 00 4F 0C 00 45 18 00 19 02 0A 00 00 00 80 00 00 00
39 39 36 32 30 31 34 38 39 34 33 4F 55 54 50 55 54 2D 53 49 54 20 20 01 20 4F 0C 40 45 18 02 19 02 0A 08 00 00 80 00 00 00 4F 0C 00 45 18 00 19 02 0A 00 00 00 80 00 00 00 43 59 2F 02 A9 83 07 F3 34 2B A1 07 40 10 10 0A AB 28 04 F2 00 35 73 14 01 4F 03 34 0D 83 EC 48 06 43 05 00 A0 00 0A 3C 00 00 19 24 01 01 02 5B FA 64 06 ED 05 31 00 01 70 1D 3D 81 10 01 00 CE 00 B7 10 14 44 3D 49 03 03 12 F9 57 A0 00 00 01 00 2F F2 20 04 18 91 0A 00 00 00 00 00 0A 14 00 00 00 00 35 00 40 01 03 00 18 00 08 23 0D 00 00 58 03 00 01 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
(Multiecuscan 5.0)
08/11/2022 10:00:15
Alfa Romeo Giulia 2.2 MultiJet 16V
CAN Setup / PROXI Alignment Procedure (952)
Controllo motore (ECM/NCM): EOL Ok
Quadro Strumenti (IPC/NQS): EOL Ok
Cambio Automatico/Robotiz. (TCM/NCA/NCR): EOL Ok
Nodo Selettore Cambio (ESM/GSM/NSC): Ok
Telematic Box Node (TBM): EOL Ok
Driver Assistant System Node (DASM): EOL Ok
Drive Train Control Node (DTCM): EOL Ok
Climatizzatore (HVAC/NCL): EOL Ok
Rear Right Climate Control Node (RRCM): Ok
Comfort Seat and Wheel Node (CSWM): EOL Ok
Left Blind Spot Sensor Node (LBSS): EOL Ok
Right Blind Spot Sensor Node (RBSS): EOL Ok
Entertainment multimedia control module (EMCM): EOL Ok
Guida Elettrica (EPS/NGE): EOL Ok
Impianto frenante (ABS/BSM/NFR): EOL Ok
Nodo Sensore Parcheggio (PAM/NSP): EOL Ok
Nodo Air Bag (NAB/ORC): EOL Ok
Nodo Controllo Corsia (HALF): EOL Ok
ATTENZIONE: Questo veicolo è già configurato correttamente. Allineamento PROXI non necessario!
ESECUZIONE ADEGUAMENTO...
Selettore di controllo dinamico
Vecchio valore: Type 3/DNA/Sport
Nuovo valore: Type 2/DNA
COMPLETATO
PROCEDURA ALLINEAMENTO PROXI
Scrittura dati configurazione CAN...
Registrazione modulo: Body Computer (BCM/NBC) FALLITO! - Errore tempo di attesa
Registrazione modulo: Controllo motore (ECM/NCM) ESEGUITO!
Registrazione modulo: Quadro Strumenti (IPC/NQS) ESEGUITO!
Registrazione modulo: Cambio Automatico/Robotiz. (TCM/NCA/NCR) ESEGUITO!
Registrazione modulo: Telematic Box Node (TBM) ESEGUITO!
Registrazione modulo: Driver Assistant System Node (DASM) ESEGUITO!
Registrazione modulo: Radio Frequency Hub Node (RFHM) ESEGUITO!
Registrazione modulo: Drive Train Control Node (DTCM) ESEGUITO!
Registrazione modulo: Climatizzatore (HVAC/NCL) ESEGUITO!
Registrazione modulo: Entertainment Telematic Node (ETM) ESEGUITO!
Registrazione modulo: Comfort Seat and Wheel Node (CSWM) ESEGUITO!
Registrazione modulo: Left Blind Spot Sensor Node (LBSS) ESEGUITO!
Registrazione modulo: Right Blind Spot Sensor Node (RBSS) ESEGUITO!
Registrazione modulo: Entertainment multimedia control module (EMCM) ESEGUITO!
Registrazione modulo: Guida Elettrica (EPS/NGE) ESEGUITO!
Registrazione modulo: Impianto frenante (ABS/BSM/NFR) ESEGUITO!
Registrazione modulo: Nodo Sensore Parcheggio (PAM/NSP) ESEGUITO!
Registrazione modulo: Nodo Air Bag (NAB/ORC) ESEGUITO!
Registrazione modulo: Nodo Controllo Corsia (HALF) ESEGUITO!
ESECUZIONE FALLITA
Registrazione modulo: Body Computer (BCM/NBC) ESEGUITO!
COMPLETATO
0=1989,1802,1872,1804
1=1989,1804,1809
2=1989,1988
3=1807,1806
4=0
5=0
6=0
7=0
8=0
9=0
Re: DNA TYPE 2 FAIL
it fails on body. try to use 4.8 version
update: it failed on body when you changed DNA from type 3 to type 2. then after you did alignment again it completed OK. so don't see where the problem is.
OFF.PAVAN
Re: DNA TYPE 2 FAIL
Post by OFF.PAVAN »
shpuncik wrote: 08 Nov 2022, 15:31 it fails on body. try to use 4.8 version
thw km pulse after one key of ande is it impossible to allineate, i can see race mode on IPC but no in ETM, and dostn work acc and pam becouse ECM need a alliniament and it fail also with mes or witech
Re: DNA TYPE 2 FAIL
when odometer is blinking, connect to CAN Setup/Proxi, disconnect and paste this log.
there won't be Race on ETM on MY20, only on IPC.
chrener
Re: DNA TYPE 2 FAIL
Post by chrener »
OFF.PAVAN wrote: 08 Nov 2022, 16:23
After proxi alignment with Driverselector or cruise control changes you have to do ABS relearn and reconfigurations...
OFF.PAVAN
Re: DNA TYPE 2 FAIL
Post by OFF.PAVAN »
[/quote]
i have performed also with witech2 and dont have sucess, fail the proxi set also by ABS ecu performing the after reprogramming procedure, i have done sucesfull this operation up to 10 cars but only this dont work
chrener
Re: DNA TYPE 2 FAIL
Post by chrener »
On models with touchscreen ETM is not possible to see RACE screen, it works only on IPC...
